I keep seeing this when I have lost ability to use the internet even though I’m connected on RT-AX86U on latest version
dgraham78
i keep seeing this when I have lost all connectivity
kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
For more context
Jul 14 12:51:00 RT-AX86U-21A8 hostapd: eth6: STA 64:cb:e9:05:e1:ed IEEE 802.11: disassociated
Jul 14 12:51:05 RT-AX86U-21A8 hostapd: eth6: STA 64:cb:e9:05:e1:ed IEEE 802.11: associated
Jul 14 12:51:05 RT-AX86U-21A8 hostapd: eth6: STA 64:cb:e9:05:e1:ed RADIUS: starting accounting session 9DF84CDE3ACF6E16
Jul 14 12:51:05 RT-AX86U-21A8 hostapd: eth6: STA 64:cb:e9:05:e1:ed WPA: pairwise key handshake completed (RSN)
Jul 14 12:51:28 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b IEEE 802.11: disassociated
Jul 14 12:51:28 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b IEEE 802.11: associated (aid 2)
Jul 14 12:51:28 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b RADIUS: starting accounting session 2131A5C87EB0A583
Jul 14 12:51:28 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b WPA: pairwise key handshake completed (RSN)
Jul 14 12:56:48 RT-AX86U-21A8 acsd: eth6: COEX: downgraded chanspec 0x1908 (10) to 0x100a (10): channel 3 used by exiting BSSs
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b5:c6:3b WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth7: STA 70:b3:06:00:11:48 WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth7: STA dc:56:e7:56:c5:8e WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth7: STA 94:ea:32:b6:01:39 WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 64:cb:e9:05:e1:ed WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth7: STA b0:e5:ef:70:21:7e WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:ab:da WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:a5:66:4a WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:c7:76 WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:c0:7e WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:af:4a WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:b8:9a WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:bc:3e WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:a7:2c WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 50:14:79:d0:4e:5b WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:a5:76:ad WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA 48:e1:e9:7b:a9:6e WPA: group key handshake completed (RSN)
Jul 14 12:59:23 RT-AX86U-21A8 hostapd: eth6: STA b0:0c:d1:a6:36:c9 WPA: group key handshake completed (RSN)
Jul 14 13:04:51 RT-AX86U-21A8 hostapd: eth7: STA 70:b3:06:00:11:48 IEEE 802.11: disassociated
Jul 14 13:04:55 RT-AX86U-21A8 hostapd: eth7: STA 70:b3:06:00:11:48 IEEE 802.11: associated (aid 4)
Jul 14 13:04:55 RT-AX86U-21A8 hostapd: eth7: STA 70:b3:06:00:11:48 RADIUS: starting accounting session BBEABF5E2755CF0E
Jul 14 13:04:55 RT-AX86U-21A8 hostapd: eth7: STA 70:b3:06:00:11:48 WPA: pairwise key handshake completed (RSN)
Jul 14 13:05:12 RT-AX86U-21A8 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
The first message is just related to trend micro. Should not be impacting your clients, probably just coincidence.
Your clients may be disconnecting due to interference, distance, roaming assistant being too aggressive, or even your radio in the router dying.
Not sure why you're seeing so many key exchanges, you may have log level set higher than me or AX may just do it more than AC.
Are disconnects happening on both 2.4 and 5ghz bands?
Maybe just your ISP having issues might not be the router at all.
The log does seem to imply wireless clients are disconnecting but that could be totally unrelated (not unusual if people are coming and going etc). So yeah sort of have to narrow down if it is a wifi or WAN issue.
Just happened again no clue what’s going on here is what was in the syslog
Just checking... After your first post did you manually reboot the router? Because this post shows the router starting up again three minutes later.
