I just wanted to say hello to everyone on SmallNetBuilder.com! This is my first post on the website and I figured I would share my brand new wireless network configuration that I put together in preparation for the PS4 this Fall.
The last time I upgraded my network was around the release of the PS3 back in 2006, so I figured I was due for an upgrade. My old wireless network consisted of a Motorola Surfboard SB5101U Cable Modem and a Linksys WRT54G2 Wireless Router, connected by a Staples Category 6 Ethernet Cable.
I have learned a lot in the past few weeks by reading reviews and threads on SmallNetBuilder.com. After a ton of research, I have created a setup that is perfect for my needs. I chose to go with the best Wireless-N setup I could get my hands on, since the PS4 does not support Wireless-AC. Below is a list of every component that makes up my new wireless network. I want to say thanks to everyone on SmallNetBuilder.com for being such a great community! I couldn't be happier with my new wireless network!!!
1. Motorola Surfboard Cable Modem SB6141 (White / Retail Version)
2. ASUS Dark Knight Router RT-N66U (Firmware upgraded to version 3.0.0.4.272)
3. ASUS Dual Band Network Adapter EA-N66 (Firmware upgraded to version 1.0.1.8f)
4. ASUS High Gain Dual-Band Antenna WL-ANT157 (Replaced all 3 stock antennas)
5. Rosewill 1 Foot Category 7 Ethernet Cable (Connects SB6141 to RT-N66U)
6. Rosewill 3 Foot Category 7 Ethernet Cable (Connects EA-N66 to PS3)
My wireless network is in a highly congested environment in the suburbs which contains a ton of activity on the 2.4 GHz band, but almost zero activity on the 5 GHz band. My wireless network is located right in the middle of my house on the top floor. I used my knowledge gained on SmallNetBuilder.com to get the most out of my new wireless network!
First, I replaced all three of the stock antennas on the RT-N66U with three of the WL-ANT157 high gain / dual band antennas to extend my overall range on the 5 GHz band, which really made a great difference. Also, the 2.4 GHz band remained excellent with the new antennas.
Next, I connected my SB6141 to the RT-N66U with a Rosewill 1 Foot Category 7 Ethernet Cable. Then, I scanned my wireless area with the inSSIDer Android App on my Galaxy S4. The high gain antennas gave me a great view of my wireless area in my neighborhood, which allowed me to choose the least crowded 2.4 GHz and 5 GHz channels for my wireless network.
The least crowded channel on the 2.4 GHz band was channel 11. On the 5 GHz band, the only channel that never picked up any kind of outside signal was channel 157. I also made sure I assigned separate SSID numbers for the 2.4 GHz and 5 GHz bands in order to avoid any possible confusion.
Once I had my channels selected, I logged into the GUI on the RT-N66U to adjust my settings and update the firmware. Once I updated the firmware to version 3.0.0.4.272, I selected the N-only and 20 MHz options for the 2.4 GHz band. Next, I selected N-only and 40 MHz on the 5 GHz band in order to get the maximum speed and connectivity for my EA-N66, which I set up next.
I started by updating my EA-N66 firmware to version 1.0.1.8f. Then, I connected the EA-N66 to my 5 GHz / 40 MHz band. Once it established a connection in Ethernet Adapter Mode, I tested it out on my laptop. I was shocked at how well the EA-N66 worked! I was getting the same speed as if I were connected directly to my modem!
Next, I went downstairs to connect the EA-N66 to my PS3 with a Rosewill 3 Foot Category 7 Ethernet Cable. I was blown away at the results! I get triple the speed, compared to when I connected my PS3 wirelessly with the Linksys WRT54G2 Wireless-G Router. I made sure I only connected my PS3 to the 5 GHz band, since it provides the best signal for online gaming and movie streaming.
I left all of my other devices on the 2.4 GHz band, which works great for web surfing and checking email. ASUS has really impressed me with this entire setup! I really doubt I will ever buy networking components from any other company in the future. Thanks for reading!!!
