System Error Message
Part of the Furniture
the first gen iseries 32nm has AES-NI, so that means it will be the minimum requirement for pfsense. On AMD side that will be the bulldozer.
And pfSense - flexibility is what it is, and sometimes at the cost of usability... done right - it's a high performance package...
nope. You can turn off VPRO.Does it make sense to have a box without Intel's V-Pro tech (IME - management engine) for pfsense/opnsense. Seems like it could be a issue for a big corp. and to have such a overlooked backdoor on your router/firewall. AMD also does something very similar. I haven't seen it discussed much, so maybe its not a issue. The J1900 cpu does not have it as far as I know, it is also missing AES instructions.
I disagree as it does not seem high performance to me and there is not just one way to setup networking. So done right has no meaning.
Whether pfSense, or any reputable system, is "high performance" or "better" is hard to quantify. Similarly, it's hard to objectively criticize without some concrete, repeatable examples of failure.
I personally chose a FreeBSD-derived OS for networking purposes because I think it has he most dependable/reputable TCP/IP stack.
I prefer certain aspects of different systems, but I hesitate to criticize a system for not being my preference.
All systems are simultaneously horrible and great. Without details, it's just a never-ending pissing match with no possible conclusion.
If the packets flow slow then it is no good.
I don't run multiple interfaces in pfsense. I have one "in" interface and one "out" interface. It does not get any simpler than that.
Whether it is a bug or not it is a problem with pfsense affecting the performance.
Thank you for posting that link. I now have it book marked. I never came across those instructions before in my pfSense searches. I had to make a few passes to have it all sink in. I don't use VLANS. But I can think of a use case or two for this now after reading the article.I've been using both DNS Resolver and DNS Forwarder on pfSense - one of the nice things about pfSense is the flexibility of assigning ranges and DNS per VLAN, and reduce the risk of DNS leakage when using OpenVPN or L2TP/IPSec.
Somebody posted a very good walk-thru on pfSense setup and configuration with multiple VLAN's and VPN setups.
https://nguvu.org/pfsense/pfsense-baseline-setup/
I can understand though why people are looking to migrate out of pfSense when using repurposed machines - pfSense 2.4 requires a 64bit CPU, and pfSense 2.5 is going to require AES-NI along with 64-bit support - which on older builds, this can be a problem.
Still think maybe there's issues with DNSResolver vs. DNSForwarder in your case - but takes some time/effort to debug, and that's a challenge for something that is still free to download and install.
Thread starter | Title | Forum | Replies | Date |
C | Using 2 routers (no bridge), DDNS configuration not working | Routers | 3 | |
B | Long shot but worth a shot? WFH using CISCO phone audio delay 5-10 seconds | Routers | 1 | |
C | Pfsense wins awards | Routers | 34 |
Welcome To SNBForums
