It provides standard 500mA power so the usb 2.5" HDDs work.
Yes is possible to map samba shares in windows assigning a drive letter.
The setup is very simple. Just open the instruction booklet or search the internet and you are there.
Jeez, whats the point of joining a forum to tell people to search the internet.
Chapel mate,...:
Is there a specific reason you need to share as a SAMBA/CIFS share? NFS is best but this router has FTP out of the box; FTP is better so far as I am concerned. here is a resource:
http://wdtvforum.com/main/index.php?topic=5393.0
doubtless windoze users will love SAMAB ; I dont for reasons I shall avoid so as to prevent unwarranted windoze lovvies trolling this thread !
FTP share is easy to setup as an FTP share, windows 7 should detect it automatically, other clients will need configuring.
what you need to do is ensure the USB drive is <=500GB - there are issues with larger drives.
gointo router settings using a web browser enter 192.168.0.1 into the address bar or whatever the address is of your router. I think the default is 192.168.0.1.
enter admin password (its in the manual) defaults to "password" I think
change the admin password - Adminstration screen
you also need to gointo settings on the router and enable FTP server. you will see the USB drive connected. make sure you share by account. the default is to use the admin account (and password).
then from your laptop/PC/client , browse the network by entering the following in the windows folder location/address bar:
ftp://192.168.0.1
you should see the USB drive and will need to enter login credentials, use those as above, for example "admin" and your new password you entered above. the USB drive should now be visible , usally as "sda1" which is a linux naming convention for a hard drive - linux is the operating system (firmware) used in the ASUS router - its open source so reduces production costs for OEMs.
the above is the basics, you can make it more secure by improving/adding accounts, but the above should get you working.
*** TIP ***
first off before attempting the above, navigate through all your router setup screens to observe the page titles, screen layout, options, current option values and so on. It will help.
Manuals are okay , but there is no substitute for human interaction and guidance.
EDIT: Im not a windoze guru and have just wondered whether windoze will even recgonise EXT4 through FTP, I'm not sure? In which case you will need to setup a SAMBA share; the process is almost identical to above albeit on a different settings screen in the router. You'll see it!
