It is something basic, but I would like to get an opinion from someone else. I made this connection as you can see in the picture via ethernet cable and everything looks "Great". I would have liked to run the RT-AX56 directly to the main router with ethernet but I don't have a direct line, so the option I had was to connect it to the second node.
The speed is fine, but I would still like to confirm if this is an acceptable topology.
Thank you in advance for your time and response
