Wireguard Import wireguard .conf file from windows
FYI,,,,,
wg_manager v4.18 includes a crude WebUI ( although Beta v4.19b3/WebUI v1.04 available from the dev Github branch is a tad better) and is shown in the commandline menu....
e.g.
and can be accessed via the Addons Tab...
e.g. You can import the WireGuard .conf directly from Windows by clicking on the Choose File button.
Latest Beta WebUI v1.04
Is there a manual to use the gui of the 4.19b3? I have not been able to use it at all, I received no response from any of the commands nor to add .conf files.
I do everything in text with amtm and work great, but I would like to be able to use the gui.
Btw, it is possible to add several wg.conf files at the same time, like in vpn director in WGM?
If the GUI is failing, then these posts might help to identify why the crude GUI is failing:
No, the Peer import command currently only processes one single filename at a time...but you could use something like the following
for FN in $(ls -l /opt/etc/wireguard.d/*.conf 2>/dev/null | awk -F '/' '{print $5}' | grep -v "wg[1-2]" | sort | column); do wgm import $FN;done
