Importing Traffic Monitor Statistics On New Router
FeRReTTi
Hey everyone!
So my AC5300 had to get replaced. Asus sent me out a replacement unit and I just got done setting it up. However, when I try to import my Traffic Monitor statistics (the cstats and rstats files) the network traffic is still not coming up. I have a cifs share mounted on my NAS that my old router was posting the files to. I have pointed this new router to the same location, but it isn't importing the data. Any ideas?
Thank you! :)
Hey everyone!
Thank you! :)
The hex string that is part of the cstats and rstats filename is the mac address (without the ':' separators, and in lower case) of the router. Rename the files with the mac of your new router.
Thank you so much! All fixed! :)
I actually do have an additional question. So, your answer worked, however, I have about 5 .bak files from when I used to track my bandwidth years ago. Is there a way I can import those as well, so I can have a more complete picture? I renamed them using the mac address, but kept the .bak file extension. However, now it is only showing the time period of the c and r stats that I just recovered. However, if I delete the newest c and r stat file, it shows my bandwidth monitoring from years ago when I used it. Any idea?
