Incoming connections
binford
Hello,
I have a ASUS RT-AC87U with Merlin firmware. VPN client is configured for PIA VPN, all outbound traffic goes through the VPN tunnel. Good.
Bad: I can not access my ipcams from "outside" over normal Provider-ip (and dyndns). Port forwarding is configured.
What must i do?
That's because you are forwarding all your traffic through the tunnel. You will have to use policy-based routing to exclude those cameras from going through the tunnel.
