Viktor Jaep
Part of the Furniture
Alrighty... I made some MTU changes to the NordVPN side of the house, and will see if I can break the router VPN by making a connection on my laptop with an even lower MTU this evening. If I can, I'll see if I can share some syslogs to see if it'll give us a cause. I really appreciate both your suggestions, @ColinTaylor and @RMerlinRegardless of what's happening with the laptop's AirVPN connection as far as the router is concerned it's just regular (UDP?) network traffic. It makes no difference that your laptop is using it for VPN, it could be being used for anything. So I can't see why (only) that would cause your router's VPN to break. The first step would be to examine the router's syslog to determine the reason why the VPN terminated.
P.S. Yes, MTU is the most obvious thing to look at (e.g.tun-mtu 1420
). You could also try switching the VPN's to TCP instead of UDP. That should be more resilient albeit at the cost of performance.
