Incorrect percentage when configuring 2nd VPN client
Thorton
I have 2 VPN clients configured. Only one of them is active at the time of course, but when I try to turn on/off or re-configure 2nd VPN client profile, firmware always asks me to wait until settings are applied up to 200%.
You know, when applying some settings, a message "Applying settings..." appears and goes from 0 to 100%. However, I usually have to wait from 0 to 200% when working with 2nd VPN client. It happens 9 out of 10 times. Using the latest firmware (AC87U).
The screen - https://s18.postimg.org/fxl8n8089/vpn.png
I believe it's a bug? Or is it a normal behavior when multiple VPNs are configured?
I've only been able to reproduce this problem twice so far, so I can't track it down. No idea what would be randomly causing this, that part of the webui code ain't exactly straightforward to understand.
Just for the record, my AC88u will exibit this same behavior. This has been happening since the open vpn 2.4 update on all the firmware version.
Actually, I think that is also about the same time that I configured a second open vpn server . Therefore, it may have always happened and I just was not aware of it. Never reported the issue because everything seems to still work.
Sent from my Pixel using Tapatalk
