spritezf
Hi guys, today we will talk about an useful feature on ASUS router which named Download Master
Step1.Plug-in a USB-HDD (up to 1GB available space) on your router’s USB port and make sure the disk mounted OK, you can check on network map page.
http://pan.baidu.com/s/1eRgU234
Step2.After disk mounted, go to USB Application page to install download master, you can find a hyperlink on the button of the page then click it, choose a partition (if you have more than one partition) which you want to install download on.
http://pan.baidu.com/s/1bje4XK
Step3.After wait a few minutes, the download master will install ok automatic, now you can use it to download files.
http://pan.baidu.com/s/1o7uRs74
http://pan.baidu.com/s/1c0UhtT2
Step4.UI will show “update available” when new version available, click the hyperlink which marked with yellow, then download master will upgrade automatically
http://pan.baidu.com/s/1eRd6E5s
Step5. If you want to uninstall download master, just needs go to USB application page and click the “uninstall”, download master will uninstall automatically
http://pan.baidu.com/s/1boeYHsz
Original Source comes from www.fansgu.com
