M
MvW
Guest
@Jack Yaz: Not sure whether intentional or even worth mentioning, but I had to start fresh today and apparently I enabled the built-in ntp-server. When I ran the ntpMerlin installer script, it detected that, disabled it but it also closed my (Putty) terminal session while at it, instead of returning to amtm. Was that intented?
And the session was unexpectedly terminated...
This installs ntpMerlin - Installer for kvic NTP Daemon
on your router.
Author: Jack Yaz
https://www.snbforums.com/threads/55756
_____________________________________________
Continue? [1=Yes e=Exit] 1
ntpMerlin: Welcome to ntpMerlin v3.2.2, a script by JackYaz
ntpMerlin: Checking your router meets the requirements for ntpMerlin
ntpMerlin: Built-in ntpd is enabled and will conflict, it will be disabled
Done.
