Installing and configuring authoritative, recursive, and DoT/DNSSEC DNS server with Unbound
This is awesome
@rgnldo, thank you very much for this!
https://nlnetlabs.nl/projects/unbound/about/
I will be trying this as soon as I can.
Do you have any suggestions on how to use this with the latest 384.11 RMerlin release and DoT it includes too? Or will they just play nice together?
Reading a bit more about this, will this affect Diversion and pixelserv-tls too?
While I appreciate having this guide and package available for our routers, I am not sure at all how it will impact the other scripts and options that we have too?
Thank you very much for this tutorial.
There are 3 things that are not correct:
1) /opt/etc/unbound/init.d/S61unbound start
Should be:
/opt/etc/init.d/S61unbound start
2) I got a failure when starting the script. It couldn't find hints.root
I got it by running the following command:
curl -o /opt/var/lib/unbound/root.hints https://www.internic.net/domain/named.cache
3) /opt/etc/unbound/unbound.conf is in 6)
In the configuration it is: /opt/var/lib/unbound/unbound.conf
I think it should be the same....
Exactly. He had forgotten. This is the authoritative dns resource
Yes. For Stubby Merlin
forward-zone:
# Cloudflare
forward-tls-upstream: yes
forward-addr: 127.0.0.1@53
I have my own adblock script, generating it for Unbound. I do not need Pixelserv-tls
I got another error:
unbound: [25585:0] fatal error: could not open autotrust file for writing, /root.key.25585-0: Permission denied (With verbosity: 2 instead of 1)
I changed unbound.conf file
username: "nobody" to:
username: "root"
I don't know this is the correct way......
Ok here.
unbound-checkconf: no errors in /opt/var/lib/unbound/unbound.conf
admin@rgnldo-lan:/tmp/home/root# /opt/etc/init.d/S61unbound check
 Checking unbound...              alive.
Can I still utilize dnsmasq.conf.add to add additional hosts?
I have long abandoned storing my manual DHCP static list in nvram and use dnsmasq.conf.add instead. Much easier to update/support and very portable!
Actually I would still like to use dnsmasq.conf.add. This is how I assign fixed IP addresses on my network. Asus nvram has limits in this area. I now use dnsmasq (via dnsmasq.conf.add).
A few more questions It looks like the main change to dnsmasq.conf is to add:
server=127.0.0.1#40
cache-size=0
Correct? In other words, can I simply add "server=127.0.0.1#40" to dnsmasq.conf.add?
Also, I assume setting dnsmasq cache-size to 0 is to let unbound do all caching?
You do not have to use it. Enough
service restart_dnsmasq
But you'll get more customization with /jffs/config/dnsmasq.conf
/jffs/config/dnsmasq.conf.add you just add rows. It will be in conflation with the line
cache.size=1500
Merlin pattern
Edit your dnsmasq.conf as you wish and restart
I see, unbound is using /jffs/config/dnsmasq.conf.
I can just add my fixed address assignments to that file just as easily. I will create a /jffs/config/dnsmasq.conf.add kind of script ">>" easy enough ;-)
Thanks @rgnldo
Perhaps I can clone the stubby installer and modify it for unbound. Am using Unbound + DoT on pfSense. Never could get the unbound part dialed in on Asuswrt-Merlin.
Keep an eye on this setting in case things go awry. /jffs/configs/dnsmasq.conf.add and Diversion ad blocker append to /etc/dnsmasq.conf. I don't think dnsmasq.conf.add can be written off completely. May be worth checking if dnsmasq.conf.add and /jffs/configs/dnsmasq.conf play well together.
The purpose of /jffs/configs/dnsmasq.conf.add is to allow users to customize the firmware dnsmasq.conf file without touching it. I think the dnsmasq.conf.add settings override any firmware settings last time I checked.
Keep an eye on this setting in case things go awry. /jffs/configs/dnsmasq.conf.add and Diversion ad blocker append to /etc/dnsmasq.conf. So I don't think dnsmasq.conf.add can be written off completely.
Using a custom dnsmasq.conf has caused issues in the past where directives/values have been modified for a new release of dnsmasq, and during the (dirty) upgrade reboot, dnsmasq didn't start.
So to play safe, use dnsmasq.conf.add, and if necessary, use dnsmasq.postconf to tweak/alter/delete any variables
e.g. 'cache-size=1500' to 'cache-size=0' (not this old discussion again! :eek:)
How does Unbound compare to the built-in DNS Privacy options ?
