It's very interesting to see all the RT-AX82U references. Maybe a release that supports the 82U is pending?
It’s part of ASUS’ GPL code, but not Merlin’s build profiles.It's very interesting to see all the RT-AX82U references. Maybe a release that supports the 82U is pending?
I installed paldier's rt-ax82u firmware on my router. It has extended jffs enabled. Cannot install entware as it complains rmerlin is not installed. Interesting.If you follow the link to GitHub the release is by someone called paldier from China.
Does it work ok? How did you install it? I'm new to this.I installed paldier's rt-ax82u firmware on my router. It has extended jffs enabled. Cannot install entware as it complains rmerlin is not installed. Interesting.
I would show you how to do it but I don't want to be held liable if you brick your router. I have been part of rmerlin's crowd since 2012-3. Learnt a few tricks and disappointments that RT-AX82U isn't being supported yet. Paldier's firmware works and he/she doesn't have rmerlin's signature to make entware installation work, unfortunately.Does it work ok? How did you install it? I'm new to this.
Welcome To SNBForums
