Tutorial Installing Rtorrent on AsusWrt Merlin routers through Entware
Which plugins you removed? I've same problem without any plugins
[elrengo@RT-AC3100]#opkg remove rutorrent-plugin*
Removing package rutorrent-plugin-mediainfo from root...
Removing package rutorrent-plugin-trafic from root...
Removing package rutorrent-plugin-_getdir from root...
Removing package rutorrent-plugin-_task from root...
Removing package rutorrent-plugin-geoip from root...
Removing package rutorrent-plugin-uploadeta from root...
Removing package rutorrent-plugin-_noty from root...
Removing package rutorrent-plugin-edit from root...
Removing package rutorrent-plugin-erasedata from root...
Removing package rutorrent-plugin-data from root...
Removing package rutorrent-plugin-unpack from root...
Removing package rutorrent-plugin-extsearch from root...
Removing package rutorrent-plugin-create from root...
Removing package rutorrent-plugin-diskspace from root...
Removing package rutorrent-plugin-check_port from root...
Removing package rutorrent-plugin-lookat from root...
Removing package rutorrent-plugin-history from root...
Removing package rutorrent-plugin-seedingtime from root...
Removing package rutorrent-plugin-source from root...
Collected errors:
* print_dependents_warning: Package rutorrent-plugin-rpc is depended upon by packages:
* print_dependents_warning: rtorrent-easy-install
* print_dependents_warning: These might cease to work if package rutorrent-plugin-rpc is removed.
* print_dependents_warning: Force removal of this package with --force-depends.
* print_dependents_warning: Force removal of this package and its dependents
* print_dependents_warning: with --force-removal-of-dependent-packages.
I have a problema on maunting device
this is my samba configuration:
the guide say mount \\\\<IP address of the network server>\\<share name> /mnt/Data/Torrent_Data -t cifs -o "username=<username>,password=<password>"
tried
mount \\\\192.168.50.1\\BackupOlindo\\TorrentData /tmp/mnt/BackupOlindo/TorrentData -t ntfs -o "username=xxxx,password=xxxxx"
but the answer is
"No such device"
help please!
tried
but the answer is
"No such device"
help please!
Those instructions are for mounting a shared folder from a network server (i.e. a NAS) on your router. It has nothing to do with the Samba shares configured on your router.
Exactly!
