Installing Skynet
keef
I tried installing Skynet from amtm and I get
Getting from fwupdate.asuswrt-merlin.net
! Module skynet.mod download failed
! using fallback server diversion.ch
I tried it from the curl command line and it just does back to the command prompt. with no error. My usb drive is freshly formatted with a 2g swap file and Diversion.
thanks
Seems like you WAN DNS settings are screwed. Check:
nslookup fwupdate.asuswrt-merlin.net
nslookup diversion.ch
cat /etc/resolv.conf
date
date
I had to re-set the router and I tried the Skynet install and was successful. Is there a test function to it?
thanks for the reply
I am getting the same problem, I've set my router to openDNS servers but skynet still fails to install.
Anything else i can try?
