Intel AX200 and AX92U - AX Wifi a lot slower compared to AC?
The AX92U is intended as an AC router with a mesh AX backhaul. Client connections should only connect to AC 2x2 radios if I'm not mistaken.
You will have to disable the mesh backhaul and use one of them as a standalone router.
That is not what I am commenting on. It seems that one band is set to AC while the other band is set to AX on the same router. I don't see this working well at all.
Gotcha, apologies.
