Inter SSID Traffic not Routing on a RT-AX86U Pro
dickeypjeep
I have a RT-AX86U Pro, and I have two separate SSIDs: one on 5GHz, one on 2.4GHz. I had to do this because of a sprinkler controller (Rachio) that doesn't work well with the shared 5/2.4 SSID configuration.
The problem I'm having is that hosts on the 2.4G SSID can't talk to hosts on the 5GHz SSID. My DNS server is a wireless pi-hole, and anything on the 2.4 GHz can't use it for DNS resolution. I've done some troubleshooting and it appears that there's no layer 2 traffic at all between the SSIDs (arps don't resolve.)
Anything going onto the ethernet/wire is fine (except it doesn't get DNS resolution locally, but its fine if I point to a public DNS).
I can't seem to find a setting to enable this traffic or figure out if its even possible. I would think it is since wired hosts can get to hosts on the wireless, but maybe this router just can't go wireless to wireless? I'm stumped!
TIA for any suggestions.
What firmware are you running on the router?
Are the WiFi clients on Guest Network (or Guest Network Pro) or the main WiFi?
Which firmware?
Per chance did you set up the 2.4 GHz SSID on a guest network?
A work around for your sprinkler is to use the Dual Band SmartConnect with the same SSID for the 2.4 and 5 GHz then set up a different SSID on a guest network on 2.4 GHz for the sprinkler.
Is there an echo here???
