Intermittent DNS failure? Dnsmasq hanging? 384.19 on RT-AX88U
johnv621
Hi all,
I've had my AX88U setup running well for several months (Diversion, SkyNet, YazFi, etc.). The issue below seemed to start occurring when I recently upgraded to 384.19. I've tried various logs/troubleshooting and can't figure out the root cause. Basically the router appears to intermittently stop responding to client DNS requests. The effect is that 70-80% of my browsing is normal, and the rest of the time I have to reload pages multiple times before the DNS resolves and the pages load. I've done several speed/load tests and there don't seem to be any connectivity issues, so I'm convinced it's a DNS problem. A few pages will load correctly, and then every few minutes one will "time out" several times but then load ~30 seconds later.
Current config is:
and I have several of the Preset IPv4 servers selected.
Using nslookup and Wireshark on the client, the client is correctly pointed to the router DNS server, but the response is "Server Fail". During this "outage", a dig command on the router for the same domain *DOES* complete successfully. Using Diversion 'f' to follow dnsmasq, the client query doesn't show up. The log will 'freeze' for 10-30 seconds, and then all of a sudden a flood of requests will come through (including the initial client request). Once this happens, a query response is received and the client page eventually loads.
If I set the clients to bypass the router DNS, everything works fine. But, I'd like to get it fixed so I can use DoT on the router.
Thoughts? Thanks in advance!
Hi all,
Current config is:
What are you using as the DoT servers?
I had the same issue using Quad9 as the DoT servers but now using google for the DNS servers and cloudflare as DoT I dont get the issue anymore.
Don't use cloudflare i had wierd issues every time i used them going to Goggle dns fixed them all.
I've had the same issue every time I switch to using DoT. For me it just flashes for like a second (showing DNS lookup error) and then it loads normally. Happens randomly, but more frequently with Quad9 and CF. Google DNS seems the most stable on DoT but it still happens once every few days.
I've experienced similar here using DoT on an AX88U. I had been using Quad9 for while with no issues then had a few things showing DNS failure, like my TV and VoIP phone not registering - I guess they tried DNS once and gave up rather than retrying - Then a few weeks back it pretty much stopped altogether. Changed to CloudFlare DoT and all working fine. I have seen a few twitter posts on Quad9 about performance and a reply from Bill Woodcock mentioning DoT obvioulsy has a fairly big increase on overhead (both ends) and sounds like some servers may be at capacity http://www.snbforums.com/threads/changing-dns-server-to-quad9.66404/post-619311
I am also experiencing this same issue now on my AX88U running merlin firmware 384.17. Did anyone else ever figure out how to fix this issue?
I haven't had any issue for like a year now using Google DNS on my DoT setting. CF still gives me intermittent errors.
RMerlin version 386.4 is recommended today. You're running very outdated firmware.
The issues here from the OP from a year and a half ago have probably been fixed by now.
yeah cf has been trash lately, slow. switched to the 9s seems to be more responsive and with dot enabled.
