Okay, I am at a loss for what to do here. I am not even really sure what to do to go about diagnosing this issue. here is my setup:
50Mbps cable internet come into Motorola SB6141.
Modem connects to Asus RT-AC87U via Cat 7 S/STP 3 foot cable.
Router connects to various devices.
Router connects to TRENDnet TEG-S80g 1 Gbps switch
Switch connects to PC and other devices including Synology DS1815+ via cat 7 S/STP cables (under 10 feet.)
Computer NIC to switch is Intel I218-V on a ASUS Sabertooth X99 motherboard.
Computer has a static network configuration on the Intel NIC as follows:
IP Address: 192.168.174.xx
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.174.xz
Synology DS1815+ also has a static network configuration as follows:
IP Address: 192.168.174.xy
Default Gateway: 192.168.174.xz.
The computer is also connected directly to Synology DS1815+ with a Cat 6a crossover cable on a
Realtek PCIe GBE Family Controller that is also a static configuration as follows
PC:
IP Address: 169.254.141.1xx
Subnet Mask: 255.255.0.0
Default Gateway: None
Jumbo frames on: 9000 bytes
Synology DS1815+
IP Address: 169.254.141.1xy
Jumbo Frames on: 9000 bytes
PC uses Google Chrome browser but issue also occurs with Firefox.
Hopefully, I have described the network adequately enough.
Now the problem started when I connected the DS1815+ via the crossover cable to the PC. before that no issues had occurred. through the local network, especially the direct connection to the NAS I am getting +/- 115 MBps transfer speeds which is close to the maximum capable throughput, which I love. The issue is when I attempt to connect to almost any website, doesn't matter what it is, or if I return to the a tab after a period of inactivity and refresh it. I usually receive a connection timeout error on the first try and this is corrected by a refresh of the page. This is quite annoying. I still seem to be receiving my full connection speed, but something is going on with the latency. Hopefully someone smarter than I will be able to assist in resolving this issue. I appreciate any assistance in advance.
Best Regards
Thomas.
PC:
Synology DS1815+
Best Regards
Thomas.
