iOS Asus Router App
Updated my router. The app is neat and a good start. Is there a practical function for the rotating graphic element? Is there any plan to allow remote logins?
You can check real-time traffic/guest network/CPU&RAM usage rate/client number by slide on the rotating graphic element
I'm seeing a bug where it shows several wireless clients as anonymous on the ios app, but they are identified as sonos play 1 devices and an amazon kindle on web interface, which I believe is correct.
I found it in the app store for my iPhone, but when I looked on my iPad, couldn't find it. it looks great so far.
Could you shared some picture for us?
OK. Here is a screen shot of the ios app, showing annon. for 168, and a screen shot of the asus standard app, showing no 168 at all. I was wrong about sonos. They are showing up fine on ios. Seems to be a ghost client that only shows up on iOS
I just switched to the new ac88u router. and the bug is gone. It seems to be specific to this app and the 87
oh there is a bug in the app which gives accessibilities to quests in your network when you thought you were disabling the quest access.
Check the samba tab and "quest login". if you turn it off, it is actually enabling the quest login. It is showing the information wrong. if you have played with the app, better to check your settings with the browser!
ios app, ac87u:
Sent from my iPad Air 2 using Tapatalk
No acess from wan? I would like to have access from wan using Asus dns.
Also iPad support.
I didn't seem to initially have this problem on my 87u, but after upgrading it to the latest Merlin firmware, I seem to also get it. I have quite a few devices shown as Anonymous. However, if you check from the Android version, it's normal.
I think that the Android version has had a few updates since release, which haven't yet come to the iOS version...
App Versions currently:
iOS: 1.0.0.0.26
Android: 1.0.0.2.33
It would be nice if the device list could be sorted alphabetically or by IP or MAC... unless I am missing something.
1.0.0.1.129 - still the same bug in the samba tab showing quest login incorrectly.
In the App Store it says that it's version 1.0.0.1.129, but when I open the app it's 1.0.0.0.29
The "What's New" isn't in English though so I have no idea what's supposed to be different.
I installed the update; it's in my languish. Have only seen Asian languish characters in the Q&A section.
Google Translate says this for the change log :
1. support for multiple languages (English, Traditional Chinese, Simplified Chinese, Russian Swedish, Dutch, German, Japanese, Korean, Thai, French, Spanish, Norwegian, Polish, Portuguese)
2. the new Terms of Use and Privacy page
3. New password lock function and support Touch ID Unlocking
Thanks!
Asus just released a new update for the app at Apple Store, now we can acess the router remotely!!! Finally, tested here and it's working well
Enviado do meu iPhone usando Tapatalk
What feature does this app offer that so many people are requesting remote access? All I want to do is be able to fire up my guest network remotely instead of walking my wife through it over the phone and I don't see guest network options anywhere.
