iOS Shortcut for Diversion
works fine here RTAC-5300
Works a treat on my RT-AC5300 - locally and remotely through OpenVPN server on the router.
BTW - if you have multiple routers - you can install multiple Diversion Adblocker shortcuts - just run the Safari URL in the original post and take option to keep prior Diversion Shortcut/s. You can then go about configuring each to connect to approriate router/s.
You can also "duplicate" an existing Shortcut by selecting the "Edit" text link top left of the Shortcuts App - then press the + box at the top right.
The Diversion shortcuts simply have an incremental number appended to each one's name. Haven't found a way to rename more meaningfully the multiple instances of the Diversion Shortcut.
Great work as usual from @thelonelycoder :D.
Tap on three dots (...) and then on the settings icon top right (the two-slider icon). Edit name to your desire.
Coming in an update, and I really start to like what's possible with Shortcuts, though limited:
Happy that this is working well for iOS devices....but where is the love for Android users? ;):D
Is there an equivalent for Android?
Is there a way to allow key OR password login on LAN and key ONLY on WAN for SSH?
No, Shortcuts only work with user/pass combo.
Which reminds me, I have a new Shortcut for Diversion 4.1.0. Just a moment (or two), need to double check some things.
iOS Shortcut v1.1 is now available
- More options and simplified menu.
- Version 1.1 requires Diversion 4.1.0.
How to install on your iOS device
See instructions in post #1, once the new Shortcut is configured and working, you may safely delete v1.0 from your Library.
Very nice, thank you
