SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
IPsec and throughput
yes i believe it is, Ipsec. I did do some test in the beginning turning the VPN off and then turning SPI off then i tried turning the entire firewall off. It is strange. nothing seems to change it.
With the LRT the SPI firewall doesn't take much processing power and should have little effect on your throughput.
What I did find was "Inter VLAN Routing" and "Content Filter" drastically reduced throughput.
I will do some throughput testing with the Gateway to Gateway connected and get back to you.
i really appreciate your time thank you, this is not my wheelhouse
OK I got it, going through all the settings on the router I can now create and remove the speed issue by enabling and disabling the DMZ port. I don't personally know why the DMZ port being active would cause this but it is. Again thanks for you help, and now i will work on cascading the connection to the Netgear.
Awesome! good job figuring this out.
I won't do the throughput testing unless you need it. I'm very busy and time is on short supply :)
