Why so many IP addresses?
and then @royarcher , go to ipv6.he.net/certification and spend an hour or two getting the first two or 3 levels of their free-of-charge online course.
Don’t enable IPv6, if you don’t need it. It’s disabled by default.
Why?
By normal IP address, I guess you mean local IP address such as 192.168.1.1 which is no good as a real address because the world and its dog use the same address on their local networks!What is the difference between a normal IP address,an IP4 and an IP6 address?
Because why enable it, if it isn't needed and adds no benefits, but potential issues? Most VPN client software blocks IPv6 to prevent leaks, DNS filtering may not work, IPv6 addresses are total gibberish, LAN devices may get exposed without you knowing... it is disabled by default for a reason.
So basically, you just don't like IPv6
If people don't use IPv6
What does it do?Why?
IPv6 is fine out there... and I do encourage people to enable it.
Thanks for the advice but I think I'll passand then @royarcher , go to ipv6.he.net/certification and spend an hour or two getting the first two or 3 levels of their free-of-charge online course.
What does it do?
Cool stuff thanks, again PS I think we got about 28 mill now but your point is still very validFor you and right now - nothing. Australia has 47,573,248 IPv4 addresses for ~25mln population. You can keep IPv6 disabled another 10 years.
28 mil
Thanks for taking the time to explain that. I sort of thought that it was something like that but not positive. Like when I have to update my IP address while using my VPN providers DNS servers ( my ddns should update it manually when it changes but is a bit slow sometimes) on the dynu page I have noticed that the IP4 address has never changed unlike my IP addressBy normal IP address, I guess you mean local IP address such as 192.168.1.1 which is no good as a real address because the world and its dog use the same address on their local networks!
Think of the internet as a single long street, and your address is just that IP4 address. Well, that used to be all well and good but a whole load more people, devices, servers, and bots have now moved in. There now comes a point when you end up having to share that IPv4 address with not only your uncle Frank but also with Karen from the gun club! So in order to still have your own address, a whole load of new numbers needed to be added - so many new numbers that a new (and somewhat incompatible) format was needed to hold the numbers.
This argument ignores the security advantage of being behind a NAT translation layer, which doesn't exist (or at least is highly deprecated) in the IPv6 world. Firewall filtering is good, but if an attacker can't even route unwanted packets to your machine, that's even better. I like defense-in-depth, so I'm in zero hurry to adopt IPv6 for my network.LAN devices getting exposed - come on, the firewall is in place, you're behind it, unless you port forward or put the lan device into the DMZ...
My Telus mobile phone doesn't have IPv6 address, for example. Not needed, not used.
For you and right now - nothing. Australia has 47,573,248 IPv4 addresses for ~25mln population. You can keep IPv6 disabled for 10 more years.
The last point @sfx2000 makes is the most important, and to @Tech9 's, that means each home/business connection might be covered, but if people want more mobile devices not connected to those...Actually none of those are valid reasons for not using IPv6
What potential issues?
VPN - if you don't control both ends, it's not private, so what's the point? (yes, to unlock content, which is why most use it)
DNS filtering - it does work, what is a problem is https for adblocking, which is a problem for ipv4 as well
So basically, you just don't like IPv6, I get it, but that is no reason to tell others not to use it because you don't like it
If people don't use IPv6, then bug reports are not filed, and those bugs are not fixed.
Thread starter | Title | Forum | Replies | Date |
Firing ddns-start on IPv6 only event! | Other LAN and WAN | 0 |
Welcome To SNBForums
