L&LD
Part of the Furniture
You may be causing your own issues by toggling options on/off past their defaults. Toggling some options isn't the same thing as leaving those options at defaults in the first place.
If you really want to test correctly (not sure if it's mentioned above already), you should do a full reset to factory defaults and proceed slowly, methodically and take good notes along the way of what you're changing and how you're testing things. Everything makes a difference.
I suspect your router isn't in a good/known state anymore. A full reset and a minimal and manual configuration to secure the router and connect to your ISP is most likely needed to get to that base level again.
www.snbforums.com
Merlin on ASUS ax86U Question
I have an ASUS AX86U and contemplating the installation of Merlin firmware. The DDNS settings on the AX86U are limited to select dns providers. If I install Merlin, will I have more flexability (choices) with the DDNS Settings? Thanks in advance!
