IPv6 on Time Warner / Native
Larry Rosenman
I tried to turn on IPv6 and icmpv6 (Ping), and UDP (NTP) seem to work. HOWEVER when I try to do anything TCP (imap/ssh/scp/http/https) it never seems to leave the RT-AC68U (Merlin 380.57).
I'd love to get this working.
any ideas?
This with:
1) Windows 10
2) FreeBSD 11
3) GenToo Linux (not sure of version)
4) Mac OS X 10.11.3
So it's fairly consistent.
Should work, but sounds like there is a dependency on certain cable modems - if you're leasing a modem from them, it should just work if you're DOCSIS 3, but if you have your own, you might need to contact TWC's customer care to get a reprovisioning of the modem...
This with:
1) Windows 10
2) FreeBSD 11
4) Mac OS X 10.11.3
These are all pretty clean for IPv6, so again, I'm suspecting either the modem, or perhaps some setting in your router - I'm assuming you have IPv6 enabled there...
Weird in any event, as you're clients are all good, so again, suspecting the modem/TWC provisioning perhaps...
when I connect directly to the modem with the GenToo box, all works.
I've looked at ALL the settings, and this is with the IPv6 Firewall OFF.
so, what settings in the AsusWRT-Merlin (V380.57) could cause OUTBOUND TCP6 issues?
(I have a host at a colocated server connected via HE.NET tunnel to test with, and NONE of the TCP packets we sent made it out)
I recommend troubleshooting in the router first if it has a command line you can access.
On the router run the below commands and post the output. You might want to blank out the ending of any Public IP Addresses in the output unless you are confident in the router's firewall config.
Linux Commands:
ifconfig
ip -6 route
ip6tables-save
cat /etc/resolv.conf
ping6 ipv6.google.com
Some PC commands:
ipconfig /all
route print
ping -6 ipv6.google.com
From the router:
admin@RT-AC68U-41B8:/tmp/home/root# ip6tables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP all anywhere anywhere rt type:0 segsleft:0
ACCEPT all anywhere anywhere state RELATED,ESTABLISHED
ACCEPT all anywhere anywhere state NEW
ACCEPT ipv6-nonxt anywhere anywhere length 40
ACCEPT udp anywhere anywhere udp spt:547 dpt:546
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp destination-unreachable
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp packet-too-big
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp time-exceeded
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp parameter-problem
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp echo-request
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp echo-reply
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 130
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 131
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 132
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp router-solicitation
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp router-advertisement
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp neighbour-solicitation
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmp neighbour-advertisement
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 141
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 142
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 143
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 148
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 149
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 151
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 152
ACCEPT ipv6-icmp anywhere anywhere ipv6-icmptype 153
Chain FORWARD (policy ACCEPT)
DROP all anywhere anywhere state INVALID
Chain OUTPUT (policy ACCEPT)
Chain PControls (0 references)
Chain UPNP (0 references)
Chain logaccept (0 references)
LOG all anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (0 references)
LOG all anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
admin@RT-AC68U-41B8:/tmp/home/root# ifconfig
br0 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
inet addr:192.168.200.11 Bcast:192.168.200.255 Mask:255.255.255.0
inet6 addr: fe80::beee:7bff:fe6f:41b8/64 Scope:Link
inet6 addr: 2605:6000:101b:8123::1/64 Scope:Global
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:17118238 errors:0 dropped:0 overruns:0 frame:0
TX packets:18042867 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2036038900 (1.8 GiB) TX bytes:18096515076 (16.8 GiB)
eth0 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
inet addr:70.113.56.244 Bcast:70.113.63.255 Mask:255.255.224.0
inet6 addr: 2605:6000:ffc0:6e:f977:fa44:111a:c602/128 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:525431734 errors:0 dropped:0 overruns:0 frame:0
TX packets:490442277 errors:559 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1234106833 (1.1 GiB) TX bytes:2965781770 (2.7 GiB)
Interrupt:179 Base address:0x4000
eth1 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
RX packets:100280252 errors:0 dropped:0 overruns:0 frame:68394324
TX packets:128863389 errors:120 dropped:0 overruns:0 carrier:0
RX bytes:602289990 (574.3 MiB) TX bytes:2078958735 (1.9 GiB)
Interrupt:163
eth2 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:BC
inet6 addr: fe80::beee:7bff:fe6f:41bc/64 Scope:Link
RX packets:442472 errors:0 dropped:0 overruns:0 frame:21483754
TX packets:3679558 errors:1395 dropped:0 overruns:0 carrier:0
RX bytes:82955937 (79.1 MiB) TX bytes:871460522 (831.0 MiB)
Interrupt:169
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:2165166 errors:0 dropped:0 overruns:0 frame:0
TX packets:2165166 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:439203138 (418.8 MiB) TX bytes:439203138 (418.8 MiB)
vlan1 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
RX packets:273836908 errors:0 dropped:0 overruns:0 frame:0
TX packets:100271712 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:178805400122 (166.5 GiB) TX bytes:81898197781 (76.2 GiB)
admin@RT-AC68U-41B8:/tmp/home/root# ip -6 route
2605:6000:400:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:700:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:c00:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:101b:8123::/64 dev br0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:ffc0:6e:f977:fa44:111a:c602 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:ffc0:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::beee:7bff:fe6f:41b8 dev vlan2 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth1 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth2 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev vlan1 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev br0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev vlan2 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
default via fe80::217:10ff:fe86:da16 dev eth0 proto kernel metric 1024 expires 1664sec mtu 1500 advmss 1440 hoplimit 64
admin@RT-AC68U-41B8:/tmp/home/root# ping6 ipv6.google.com
PING ipv6.google.com (2607:f8b0:4002:c07::66): 56 data bytes
64 bytes from 2607:f8b0:4002:c07::66: seq=0 ttl=49 time=53.115 ms
64 bytes from 2607:f8b0:4002:c07::66: seq=1 ttl=49 time=59.692 ms
^C
--- ipv6.google.com ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 53.115/56.403/59.692 ms
admin@RT-AC68U-41B8:/tmp/home/root# cat /etc/resolv.conf
nameserver 127.0.0.1
from Win 10:
From the Windows 10 PC:
$ ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : lrosenman-w520
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lerctr.org
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 24-77-03-78-66-09
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : lerctr.org
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection
Physical Address. . . . . . . . . : 3C-97-0E-24-B4-1D
IPv6 Address. . . . . . . . . . . : 2605:6000:101b:8123:8960:77df:23a8:fcf(Preferred)
Temporary IPv6 Address. . . . . . : 2605:6000:101b:8123:bcee:525e:889:2788(Preferred)
Link-local IPv6 Address . . . . . : fe80::8960:77df:23a8:fcf%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.200.75(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, January 17, 2016 12:23:10 PM
Lease Expires . . . . . . . . . . : Monday, January 18, 2016 2:08:08 PM
Default Gateway . . . . . . . . . : fe80::beee:7bff:fe6f:41b8%4
192.168.200.11
DHCP Server . . . . . . . . . . . : 192.168.200.11
DHCPv6 IAID . . . . . . . . . . . : 71079694
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-2C-8A-80-3C-97-0E-24-B4-1D
DNS Servers . . . . . . . . . . . : 2605:6000:101b:8123::1
192.147.25.65
8.8.8.8
192.168.200.11
Primary WINS Server . . . . . . . : 192.168.200.23
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
lerctr.org
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
Physical Address. . . . . . . . . : 24-77-03-78-66-08
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:10d3:30b8:b98e:c70b(Preferred)
Link-local IPv6 Address . . . . . : fe80::10d3:30b8:b98e:c70b%18(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 318767104
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.lerctr.org:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
larry@lrosenman-w520 ~
$ route print
Interface List
5...24 77 03 78 66 09 ......Microsoft Wi-Fi Direct Virtual Adapter
4...3c 97 0e 24 b4 1d ......Intel(R) 82579LM Gigabit Network Connection
2...24 77 03 78 66 08 ......Intel(R) Centrino(R) Ultimate-N 6300 AGN
1...........................Software Loopback Interface 1
18...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
19...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.200.11 192.168.200.75 10
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.200.0 255.255.255.0 On-link 192.168.200.75 266
192.168.200.75 255.255.255.255 On-link 192.168.200.75 266
192.168.200.255 255.255.255.255 On-link 192.168.200.75 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.200.75 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.200.75 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
4 266 ::/0 fe80::beee:7bff:fe6f:41b8
1 306 ::1/128 On-link
18 306 2001::/32 On-link
18 306 2001:0:9d38:6ab8:10d3:30b8:b98e:c70b/128
On-link
4 266 2605:6000:101b:8123::/64 On-link
4 266 2605:6000:101b:8123:8960:77df:23a8:fcf/128
On-link
4 266 2605:6000:101b:8123:bcee:525e:889:2788/128
On-link
4 266 fe80::/64 On-link
18 306 fe80::/64 On-link
18 306 fe80::10d3:30b8:b98e:c70b/128
On-link
4 266 fe80::8960:77df:23a8:fcf/128
On-link
1 306 ff00::/8 On-link
4 266 ff00::/8 On-link
18 306 ff00::/8 On-link
Persistent Routes:
None
$ ping -6 ipv6.google.com
Pinging ipv6.l.google.com [2607:f8b0:4002:c06::8a] with 32 bytes of data:
Request timed out.
Only the default route and the one below are needed.
I'm not sure why the other 4 are there.
Why do you have the forward ip6tables rules?
Another helpful command from the router is:
traceroute -6 ipv6.google.com
PC:
tracert -6 ipv6.google.com
