IPv6 on Time Warner / Native
router:
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Thu Dec 24 18:54:10 UTC 2015
admin@RT-AC68U-41B8:/tmp/home/root# traceroute -6 ipv6.google.com
traceroute to ipv6.google.com (2607:f8b0:4000:80a::200e), 30 hops max, 16 byte packets
1 * * *
2 2605:6000:0:4::e:338e (2605:6000:0:4::e:338e) 24.758 ms 21.822 ms 10.574 ms
3 2605:6000:0:4::3:365 (2605:6000:0:4::3:365) 32.938 ms 4.716 ms 13.683 ms
4 * * *
5 * * *
6 2001:1998:0:4::112 (2001:1998:0:4::112) 21.409 ms 20.606 ms 15.961 ms
7 2610:18:10f:4000::3d (2610:18:10f:4000::3d) 35.352 ms 22.112 ms 27.366 ms
8 2610:18::5401 (2610:18::5401) 48.416 ms 74.509 ms 46.825 ms
9 2610:18::5804 (2610:18::5804) 48.304 ms 48.143 ms 39.624 ms
10 2610:18::5803 (2610:18::5803) 64.601 ms 44.091 ms 60.322 ms
11 cir1.chicago2-il.us.xo.net (2610:18::10d0) 45.552 ms 42.134 ms 51.829 ms
12 2610:18:111:4000::86 (2610:18:111:4000::86) 50.088 ms 48.668 ms 46.964 ms
13 * * *
14 2001:4860::8:0:9150 (2001:4860::8:0:9150) 42.166 ms 43.158 ms 58.596 ms
15 2001:4860::8:0:bb10 (2001:4860::8:0:bb10) 63.365 ms 76.073 ms 58.080 ms
16 2001:4860::8:0:2c9d (2001:4860::8:0:2c9d) 53.115 ms 47.252 ms 42.089 ms
17 2001:4860::1:0:57f (2001:4860::1:0:57f) 47.861 ms 60.865 ms 51.289 ms
18 2001:4860:0:1::84b (2001:4860:0:1::84b) 61.593 ms 57.320 ms 38.056 ms
19 dfw06s46-in-x0e.1e100.net (2607:f8b0:4000:80a::200e) 41.499 ms 52.083 ms 47.347 ms
Win 10:
larry@lrosenman-w520 ~
$ tracert -6 ipv6.google.com
Tracing route to ipv6.l.google.com [2607:f8b0:4000:80a::200e]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 2605:6000:101b:8123::1
2 * * * Request timed out.
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 *
FreeBSD:
borg.lerctr.org /home/ler $ ifconfig
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4219b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MAGIC,VLAN_HWTSO>
ether 00:30:48:f2:29:9c
nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
em1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
status: active
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
inet 127.0.0.1 netmask 0xff000000
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
groups: lo
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
inet 192.168.200.4 netmask 0xffffff00 broadcast 192.168.200.255
inet 192.168.200.9 netmask 0xffffffff broadcast 192.168.200.9
inet6 fe80::230:48ff:fef2:299c%lagg0 prefixlen 64 scopeid 0x4
inet6 2605:6000:101b:8123:230:48ff:fef2:299c prefixlen 64 autoconf
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
status: active
groups: lagg
laggproto loadbalance lagghash l2,l3,l4
laggport: em0 flags=4<ACTIVE>
laggport: em1 flags=4<ACTIVE>
lo1: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
inet 172.17.42.1 netmask 0xffff0000
groups: lo
borg.lerctr.org /home/ler $ netstat -rn
Routing tables
Internet:
Destination Gateway Flags Netif Expire
default 192.168.200.11 UGS lagg0
127.0.0.1 link#3 UH lo0
172.17.42.1 link#5 UH lo1
192.168.200.0/24 link#4 U lagg0
192.168.200.4 link#4 UHS lo0
192.168.200.9 link#4 UHS lo0
192.168.200.9/32 link#4 U lagg0
Internet6:
::/96 ::1 UGRS lo0
default fe80::beee:7bff:fe6f:41b8%lagg0 UG lagg0
::1 link#3 UH lo0
::ffff:0.0.0.0/96 ::1 UGRS lo0
2605:6000:101b:8123::/64 link#4 U lagg0
2605:6000:101b:8123:230:48ff:fef2:299c link#4 UHS lo0
fe80::/10 ::1 UGRS lo0
fe80::%lo0/64 link#3 U lo0
fe80::1%lo0 link#3 UHS lo0
fe80::%lagg0/64 link#4 U lagg0
fe80::230:48ff:fef2:299c%lagg0 link#4 UHS lo0
ff02::/16 ::1 UGRS lo0
borg.lerctr.org /home/ler $ ping6 ipv6.google.com
PING6(56=40+8+8 bytes) 2605:6000:101b:8123:230:48ff:fef2:299c --> 2607:f8b0:4002:c09::64
^C
--- ipv6.l.google.com ping6 statistics ---
6 packets transmitted, 0 packets received, 100.0% packet loss
borg.lerctr.org /home/ler $ traceroute6 ipv6.google.com
traceroute6 to ipv6.l.google.com (2607:f8b0:4002:c09::64) from 2605:6000:101b:8123:230:48ff:fef2:299c, 64 hops max, 12 byte packets
1 2605:6000:101b:8123::1 0.322 ms 0.446 ms 0.223 ms
^C
borg.lerctr.org /home/ler $ traceroute6 -n ipv6.google.com
1 2605:6000:101b:8123::1 0.341 ms 0.207 ms 0.231 ms
2 * * *
3 * *^C
Just one more command left:
cat /etc/sysctl.conf
With all this information we should be able to figure this out.
admin@RT-AC68U-41B8:/tmp/home/root# cat /etc/sysctl.conf
cat: can't open '/etc/sysctl.conf': No such file or directory
admin@RT-AC68U-41B8:/tmp/home/root# sysctl -a
-sh: sysctl: not found
Maybe the Merlin system use a different process for kernel options than sysctl. It would have been nice to see if "net.ipv6.conf.all.forwarding=1" was set because that could explain why the router isn't forwarding.
Everything looks good except for the unexplained routes below:
2605:6000:400:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:700:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:c00:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
For HE IPv6 I recommend MTU of 1280.
admin@RT-AC68U-41B8:/proc/sys/net/ipv6/conf/all# ls
accept_dad accept_source_route forwarding router_probe_interval
accept_ra autoconf hop_limit router_solicitation_delay
accept_ra_defrtr dad_transmits max_addresses router_solicitation_interval
accept_ra_pinfo disable_ipv6 mc_forwarding router_solicitations
accept_ra_rtr_pref force_mld_version mtu
accept_redirects force_tllao proxy_ndp
admin@RT-AC68U-41B8:/proc/sys/net/ipv6/conf/all# cat forwarding
1
turned on DHCP_PD for IPv6:
$ ping -6 ipv6.google.com
Pinging ipv6.l.google.com [2607:f8b0:4002:c0c::8b] with 32 bytes of data:
Reply from 2607:f8b0:4002:c0c::8b: time=54ms
Reply from 2607:f8b0:4002:c0c::8b: time=52ms
Reply from 2607:f8b0:4002:c0c::8b: time=55ms
Reply from 2607:f8b0:4002:c0c::8b: time=57ms
Ping statistics for 2607:f8b0:4002:c0c::8b:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 52ms, Maximum = 57ms, Average = 54ms
BUT TCP still fails
$ tracert -6 -d ipv6.google.com
Tracing route to ipv6.l.google.com [2607:f8b0:4002:c0c::8b]
1 <1 ms <1 ms <1 ms 2605:6000:101b:8101::1
3 24 ms 39 ms 21 ms 2605:6000:0:4::e:33a2
4 14 ms 16 ms 18 ms 2605:6000:0:4::3:367
8 17 ms 20 ms 19 ms 2001:1998:0:4::114
9 27 ms 20 ms 24 ms 2610:18:10f:4000::3d
10 52 ms 50 ms 57 ms 2610:18::5401
11 68 ms 56 ms 46 ms 2610:18::5804
12 45 ms 66 ms 71 ms 2610:18::5803
13 47 ms 87 ms 55 ms 2610:18::10d0
14 53 ms 45 ms 50 ms 2610:18:111:4000::86
15 60 ms 44 ms 50 ms 2001:4860::1:0:aa7a
16 66 ms 74 ms 62 ms 2001:4860::8:0:9150
17 58 ms 64 ms 60 ms 2001:4860::8:0:52bb
18 56 ms 54 ms 57 ms 2001:4860::2:0:878b
19 * * * Request timed out.
20 68 ms 62 ms 61 ms 2607:f8b0:4002:c0c::8b
Trace complete.
$ route print
Interface List
5...24 77 03 78 66 09 ......Microsoft Wi-Fi Direct Virtual Adapter
4...3c 97 0e 24 b4 1d ......Intel(R) 82579LM Gigabit Network Connection
2...24 77 03 78 66 08 ......Intel(R) Centrino(R) Ultimate-N 6300 AGN
1...........................Software Loopback Interface 1
18...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
19...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.200.11 192.168.200.75 10
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.200.0 255.255.255.0 On-link 192.168.200.75 266
192.168.200.75 255.255.255.255 On-link 192.168.200.75 266
192.168.200.255 255.255.255.255 On-link 192.168.200.75 266
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.200.75 266
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.200.75 266
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
4 266 ::/0 fe80::beee:7bff:fe6f:41b8
1 306 ::1/128 On-link
18 306 2001::/32 On-link
18 306 2001:0:9d38:6ab8:10d3:30b8:b98e:c70b/128
On-link
4 266 2605:6000:101b:8101::/64 On-link
4 266 2605:6000:101b:8101:8960:77df:23a8:fcf/128
On-link
4 266 2605:6000:101b:8101:a0e8:85a4:abf5:d84b/128
On-link
4 266 fe80::/64 On-link
18 306 fe80::/64 On-link
18 306 fe80::10d3:30b8:b98e:c70b/128
On-link
4 266 fe80::8960:77df:23a8:fcf/128
On-link
1 306 ff00::/8 On-link
4 266 ff00::/8 On-link
18 306 ff00::/8 On-link
Persistent Routes:
None
$ ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : lrosenman-w520
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lerctr.org
Wireless LAN adapter Local Area Connection* 2:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 24-77-03-78-66-09
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : lerctr.org
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection
Physical Address. . . . . . . . . : 3C-97-0E-24-B4-1D
Link-local IPv6 Address . . . . . : fe80::8960:77df:23a8:fcf%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.200.75(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, January 17, 2016 12:23:10 PM
Lease Expires . . . . . . . . . . : Monday, January 18, 2016 2:08:08 PM
Default Gateway . . . . . . . . . : 192.168.200.11
DHCP Server . . . . . . . . . . . : 192.168.200.11
DHCPv6 IAID . . . . . . . . . . . : 71079694
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-2C-8A-80-3C-97-0E-24-B4-1D
DNS Servers . . . . . . . . . . . : 2605:6000:101b:8101::1
192.147.25.65
8.8.8.8
192.168.200.11
Primary WINS Server . . . . . . . : 192.168.200.23
NetBIOS over Tcpip. . . . . . . . : Enabled
Connection-specific DNS Suffix Search List :
lerctr.org
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
Physical Address. . . . . . . . . : 24-77-03-78-66-08
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:10d3:30b8:b98e:c70b(Preferred)
Link-local IPv6 Address . . . . . : fe80::10d3:30b8:b98e:c70b%18(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 318767104
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.lerctr.org:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
admin@RT-AC68U-41B8:/tmp/home/root# ifconfig
br0 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
inet addr:192.168.200.11 Bcast:192.168.200.255 Mask:255.255.255.0
inet6 addr: fe80::beee:7bff:fe6f:41b8/64 Scope:Link
inet6 addr: 2605:6000:101b:8101::1/64 Scope:Global
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:33752 errors:0 dropped:0 overruns:0 frame:0
TX packets:22721 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4789887 (4.5 MiB) TX bytes:8440855 (8.0 MiB)
eth0 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
inet addr:70.113.56.244 Bcast:70.113.63.255 Mask:255.255.224.0
inet6 addr: 2605:6000:ffc0:6e:505f:3b71:7df6:7e8e/128 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:784029 errors:0 dropped:0 overruns:0 frame:0
TX packets:776885 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:755259561 (720.2 MiB) TX bytes:754916821 (719.9 MiB)
Interrupt:179 Base address:0x4000
eth1 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
RX packets:20186 errors:0 dropped:0 overruns:0 frame:15167
TX packets:23940 errors:2 dropped:0 overruns:0 carrier:0
RX bytes:5975760 (5.6 MiB) TX bytes:6583550 (6.2 MiB)
Interrupt:163
eth2 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:BC
inet6 addr: fe80::beee:7bff:fe6f:41bc/64 Scope:Link
RX packets:5106 errors:0 dropped:0 overruns:0 frame:47443
TX packets:11211 errors:6 dropped:0 overruns:0 carrier:0
RX bytes:1476317 (1.4 MiB) TX bytes:1902681 (1.8 MiB)
Interrupt:169
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:4142 errors:0 dropped:0 overruns:0 frame:0
TX packets:4142 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:831911 (812.4 KiB) TX bytes:831911 (812.4 KiB)
vlan1 Link encap:Ethernet HWaddr BC:EE:7B:6F:41:B8
RX packets:332235 errors:0 dropped:0 overruns:0 frame:0
TX packets:100998 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:229894371 (219.2 MiB) TX bytes:18029441 (17.1 MiB)
admin@RT-AC68U-41B8:/tmp/home/root# ip -6 route show
2605:6000:101b:8101::/64 dev br0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:ffc0:6e:505f:3b71:7df6:7e8e dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
2605:6000:ffc0:6e::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::beee:7bff:fe6f:41b8 dev vlan2 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth1 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev eth2 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev vlan1 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev br0 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
fe80::/64 dev vlan2 proto kernel metric 256 mtu 1500 advmss 1440 hoplimit 0
default via fe80::217:10ff:fe86:da16 dev eth0 proto kernel metric 1024 expires 1495sec mtu 1500 advmss 1440 hoplimit 64
What command line test or website are you using to test TCP?
Did you ping and tracert to that website?
Disregard it was a delayed SNB email I mentioned.
