sfx2000
Part of the Furniture
It's also the way to get in trouble. It's Disabled by default in Asuswrt for a reason.
Not sure why this is always the default answer...
If people don't enable/test IPv6, then bugs are not going to be found.
My ISP facing device is a modem/router Technicolor TG789vac V2 (supplied by ISP). It is in router mode (maybe I should bridge it?). So my RT-AC86U is getting an IP issued by the Technicolor's DHCP. Is that a sub-optimal setup? By the way, one of the reason why I still keep using the Technicolor (over 5 years old) is it gave me the best down/upload speeds compared to 2 others I have tried. I churn my ISP every 6 months and no matter which ISP the Technicolor just auto-configure and works. So good that I bought another same Technicolor on FB for $10 as spare!I still believe @nospamever has modem/router ISP device.
What WAN IP you are getting on your Asus router, @nospamever? Public or private?
Main GUI page:
Keep in mind this shouldn't be confused with a GCNAT modem which would provide a range of between 100.64.0.0 and 100.127.255.255.
I would imagine bridging it would definitely be a different experience. You actually have several options at your finger tips.My ISP facing device is a modem/router Technicolor TG789vac V2 (supplied by ISP). It is in router mode (maybe I should bridge it?). So my RT-AC86U is getting an IP issued by the Technicolor's DHCP. Is that a sub-optimal setup? By the way, one of the reason why I still keep using the Technicolor (over 5 years old) is it gave me the best down/upload speeds compared to 2 others I have tried. I churn my ISP every 6 months and no matter which ISP the Technicolor just auto-configure and works. So good that I bought another same Technicolor on FB for $10 as spare!
I have a 100/20 fibre broadband plan. My speed test taken 30secs ago.
Why users as guinea pigs is always the default expectation? Whoever invented this Big Mac protocol is responsible for testing.
Not a science project - vendors need to get with the program.
Talk to the vendors then. We have waited for 20 years, no problem to wait for 20 more. Take your time. Let us know when ready.
You sound like not very sure current IPv6 implementation is working well.
I'm still waiting for a real IPv6 benefit example when public IPv4 address is available. Then I may take a look.
Congratulations on the code five years after IPv6 become Internet standard.![]()
Awesome work!Easy enough - leading by example... put up or shut up on ipv6
Dropbox - Error - Simplify your life
www.dropbox.com
AsusWRT is a bit broken here...
If it's broken, can you help in fixing it? This is going to be real help for the community. Asking users to test and report doesn't work. First, they don't know how/what to test; second, they don't know how/who to report to. You also have to give better reasons to enable IPv6 than test and report.
I think the biggest issue I ever ran into using dual router (double nat) configuration is a few clients did not want to play right with properly maintaining their outbound/inbound traffic. To solve the issue, I had to place the second router in the DMZ of the first which is counter to the protection allotted by double firewalls.If you are running dual chained routers then passthrough mode is your only option on the asus, however you need to ensure that Technicolor router has a decent firewall in it. But if you don't have a specific need for IPv6, just leave it off.
If their router supports bridge, personally I prefer that (either that or using the asus as an AP if their router has a decent firewall etc) but for most people having dual routers it won't matter much, if at all. Technically it provides a bit more security.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
