Passthrough doesn't work for me...only native.Any info on how to setup IPv6 with comcast/xfinity? Connection type ative, passthrough, etc? What about settings for DNS?
Same here, It should be set to native. Passthrough is a bridging mode to connect devices to IPv6. It comes with lots of disadvantages over a full native IPv6 implementation.Passthrough doesn't work for me...only native.
IPv6 DNS Setting can be set to Disable if you want to specify another DNS resolver than your ISP's. Mine points to Cloudflare:
That's right.IPv6 DNS Setting can be set to Disable if you want to specify another DNS resolver than your ISP's. Mine points to Cloudflare:
I was set to Native but upon testing to respond to this thread it said no connectivity. I recently switched modems from a Motorola 8600 to Comcast's Technicolor CGM4140COM and now I'm wondering if that's the reason why. It's a gateway device but it is currently set in bridge mode and is connected to my RT-AC86U. The passthrough setting does give connectivity but I see from other posts here that that is not a desirable solution.Passthrough doesn't work for me...only native.
That's right.
- I am in a suburb of a city which has a Cloudflare data center. It is about 6 hops and 10 msec away. I am not paying a performance penalty outside of what is inherent to DNS over TLS, although more knowledgeable folks have stated that DNS performance would need to be very bad for you to notice.
It will push your router's IP in addition to user-specified DNS to all your devices. If you enable, it will use the routers own cache + user-specified DNS, or disable, and it will bypass the local cache and always go to the user-specified DNS. I always use yes, because I have a simple home network. Others use no because they are running specialized programs/scripts.
I have my RT-AC86U set to "Passthrough" and it passes the IPv6 test at the below link.
https://test-ipv6.com/
Welcome To SNBForums
