YazFi Ipv6 subnets
@SomeWhereOverTheRainBow
I tried adding this:
pc_replace "dhcp-range=lan,::,constructor:br0,ra-stateless,64,600" "dhcp-range=lan,fdff:a37f:fa75:1::,constructor:br0,ra-stateless,64,600" $CONFIG
And confirmed that /etc/dnsmasq.conf now had:
But when I tried to reconnect I couldn't anymore... after managing to remove the line and restart dnsmasq I checked the sys-log:
dnsmasq[28549]: prefix must be zero with "constructor:" argument at line 21 of /etc/dnsmasq.conf
So, this only works for the 64 suffix bits and not the prefix.
Tried again and change the prefix in the command to 56 and range ::1:0:0:0:0 - ::1:ffff:ffff:ffff:ffff
dhcp-range=lan,::1:0:0:0:0,::1:ffff:ffff:ffff:ffff,constructor:br0,ra-stateless,56,600
But now I learned from my mistake and checked syslog before reconnecting:
dnsmasq[26461]: prefix length must be at least 64 at line 21 of /etc/dnsmasq.conf
One final attempt:
dhcp-range=lan,::1:0:0:0,::1:ffff:ffff:ffff,constructor:br0,ra-stateless,64,600
Figuring I could use smaller subnets and it was atleast accepted by the system.
But it did not do any change. Adresses on br0 did not comply with the limited adress and wl1.2 still get br0 adresses.
Bummer...
This could possibly be because the lan prefix I entered in gui is 64... will try to change that to 48 tomorrow... I'm curious how the adresses gets arranged and may permit me to use the above command with 48 prefix and limit the range since SLAAC only needs the last 64 bits...
To let you know how I now deal with the contructor issue, I just completely remove its syntax.. e.g.
pc_replace "86400s" "infinite" $CONFIG
sed -i 's/^\(.*ra-stateless.*\),[0-9]\+$/\1,infinite/' $CONFIG
pc_replace "dhcp-range=lan,::,constructor:br0,ra-stateless,64,infinite" "dhcp-range=lan,fda8:b323:6212:3899::2,fda8:b323:6212:3899::500,slaac,ra-names,64,infinite" $CONFIG
