Is it possible to create ssids each connected to its own vlan for my parents and my own network without conflict?
i have a public wan ip,
The reason i also disabled bridge-mode initially was because my asus router(RT-AX82U) randomly kept shutting down, so that was the main reason i disabled bridge-mode, and then when doing that i forgot it caused a double nat issue. at the time i was still on the stock asus firmware and that might've had a bug that kept shutting down my router
Some Asus routers have issues holding the WAN connection alive and ISP equipment in router mode indeed solves the problem, but if this is the case you don't really have much options other than replacing your Asus router with something else.
that sucks, than i might have to find a different alternative, i'll do some research on my own
thanks for helping me!
