Hello,
I have AiMesh with AX-86U (1 main and 1 node). I split 2.4 & 5ghz into two different SSID xxxx-2.4 & xxxx-5ghz. It's been reliable AiMesh, Wifi .. Does splitting 2.4/5Ghz to two different SSID make WiFi6 not working (as I heard Wifi6 needs both 2.4 & 5Ghz to work)? Do i need to enable 160Mhz to have Wifi6 enabled or my current configuration/setting below is Wifi6 already enabled? Beside, does it also need to enable Smart Connect for Wifi6 to work?
It's been awhile I hadn't been much into wifi things since AX86U's so reliable/smooth until Wifi 7 came out and then maybe time to upgrade 6E,, wondering do I even have wifi 6 since AX86U is wifi6 router....??LOL
Thank you very much for everyone's input/help and advice!
Regards,
Jake
Regards,
Jake
