Wonder if AIMesh will be interpreted in the US as adjusting transmission radio power restrictions, re the thrashing Asus took in the 20-year agreement fine-audit? One would think If AIMesh is to work as it should, the routers have to be allowed to adjust the transmit power between them, which the agreement sort of hampers depending how it's read. Some who have tried this with the routers in the current list have reported that this either isn't showing up or isn't working/performing, but it's still very early to think it will right the first time.
As long as the firmware and radios can compensate automatically without limiting any of the feature sets, then AIMesh will be a good thing. One would think the 3200 with it's smart-connect feature, despite the relatively low amount of RAM/NVRAM, should adapt to mesh as well as any of the models. Many users have been prone to just cranking radio transmit power all the way up and leaving it there for range, so this will give everyone decent range and years of extended usefulness for all of the models they can extend it to. It may yet make up for some of the problems (and lots of buggy code) of the past, if the bugs go away in short order. I'd be happy with this, -if- the routers involved aren't locked or prohibited from being rolled back to the prior FW version they were on. This has to be considered if the user isn't happy with the way AIMesh does or doesn't perform for them. It's a big rabbit for Asus to pull out of the hat.
