Is there a way to end a DHCP lease from router?
It seems a pretty basic function for a router to accurately display all the clients connected to it, and to be able to cancel a DHCP lease.
No, it's not. DHCP leases can only be released by a client, a server cannot force a release. It could issue a FORCERENEW request, but not all DHCP clients support it.
I should have been clearer and specified cancelling a redundant lease. Rebooting the Asus clears the redundant DHCP addresses from the client list and allows the active fixed IP to be displayed, but this should not be necessary. The server would not be forcing a release, as the client is not connected to the DHCP address, and never will be again.
But the server has no way of knowing what the client is doing or if or why it is unreachable. Assuming that the client was offline and therefore freeing up the IP for another device would lead to all sorts of bad things. :)
I must be misunderstanding how this works. I thought that when the client connects with DHCP the router allocates an address of its choice, which the client just accepts.
But this does not address the problem. Only the Asus shows the DHCP address as the working connection after the client device has been reconnected with a fixed IP. This is a bug, not a feature.
@Richard20 If you cleared the DHCP lease file using the method in post #13 the problem isn't with DHCP.
More likely it's an issue with the client list itself, which is generated by the closed-source network map code. So this would be something Asus will have to fix. There was a similar discussion here where a transient IP address never disappeared from the client list.
Thanks for the replies, everyone.
Asus don't seem very responsive to this kind of annoyance, but there is always hope. I sometimes wonder if they ever actually use their own products.
Your client has to release the dhcp lease if you want it off your dhcp server’s lease list.
If your client doesn’t release the least first, the dhcp server doesn’t know it is connecting with a static op.
This is not a bug, this is simply how it works.
The dhcp server does not go comparing MAC addresses of connected devices to see if it should drop leases from machines that connect with a static IP.
I don't care if the lease remains on the server's lease list. I just want the Asus connected clients list to show the IP in use, not a redundant one which was once used to set up a fixed IP and then disconnected. Showing an IP as connected when it is not connected looks very much like a bug to me.
In other words, I would like it to behave like every other router I have used.
Just click on Refresh then, networkmap will initiate a complete rescan of the network through ARP, and will build a list based on what devices are actively found then.
I think he wants the dhcp lease list updated.
I'd suggest he shorten the dhcp least time if it really bothers him.
It's not going to remove unexpired leases that aren't being used (due to his assignment of static ips on the client), but it will age them off the list quicker.
No, it won't. That is the problem.
Colin Taylor's answer looks right to me. This is something only Asus can fix.
killall dnsmasq
rm /var/lib/misc/dnsmasq.leases
service restart_dnsmasq
Basically removed the /tmp before /var
Alternative: don't remove the file. Edit the lease file and remove the entries that you need to remove, and then restart the dnsmasq file.
killall dnsmasq
nano /var/lib/misc/dnsmasq.leases
With that you have removed the DNS lease - don't forget to restart the device (or DHCP renew command on device OS) so that device can get new lease.
What you're describing makes no sense. The router doesn't create or renew leases by itself. It only does so when requested to do so by a client.
To delete all the current leases log into the router an issue the following commands:
killall dnsmasq; rm /var/lib/misc/dnsmasq.leases; service restart_dnsmasq
EDIT: Corrected filename based on info from @kernol below. Also changed commands to be issued all at once because if you're to slow entering the commands watchdog will restart dnsmasq before you do.
Thank you @ColinTaylor. I have a new AP that would not switch to the manually set DHCP address. It would constantly pick up the "old" DHCP address in the leases table. Once I removed the leases table, it picked up the manually assigned DHCP address. Seems like if this is the default behavior of clients, then when a manually assigned DHCP address is added, Asus should remove this from the leases table.
