Is there a way to switch a led to a specific colour by calling into a c program ?
elfara
I just want to play or control the leds of my router by implementing a c program, is this possible ?
Anything is possible.
Depending on your router, firmware, and your scripting capabilities, maybe not.
What router? What firmware?
This is also in the completely wrong sub-forum, and with the wrong label...
My router is RT-AX86U Pro but I looked at scripting for it and found nothing so I would have some advice for scripting I missed for that or a way in C to write about. Thanks
Again, what firmware?
Moving thread to a more appropriate location.
The router LEDs aren`t RGB, they are single colour.
Controlling them requires accessing the GPIOs or accessing the switch API, both would require access to either Broadcom's non-public documentation, or figuring out Asus' implementation for GPIO-controlled LEDs.
Thank you for your reply but I thought it was RGB since leds can be red for example, and that by inspecting the c code in merlin's sources concerning leds (leds-monitor) there are RGB statements so I am puzzled. Otherwise, I would have liked to have been able to make them do a back and forth effect for example after an action or notification of some kind. Maybe someone knows which API to use or have an idea to move me forward? 😊
The WAN LED is two separate LEDs - one red, and one white.
The RGB lighting is only on ROG models, where there is an RGB logo in addition to the regular status LEDs.
