SNBForums
This is a sample guest message. Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Is this message normal, or a problem?
RocketJSquirrel
I see this in my log at every boot. Are these I/O errors "normal" in any way, or do I have a real problem? The attached device is a very vanilla Seagate USB2 2 TB hard drive formatted as ext3.
Dec 31 16:00:13 kernel: sd 0:0:0:0: [sda] Result: hostbyte=0x00 driverbyte=0x08
Dec 31 16:00:13 kernel: sd 0:0:0:0: [sda] Sense Key : 0x3 [current]
Dec 31 16:00:13 kernel: Info fld=0x0
Dec 31 16:00:13 kernel: sd 0:0:0:0: [sda] ASC=0x11 ASCQ=0x0
Dec 31 16:00:13 kernel: end_request: I/O error, dev sda, sector 0
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 0
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 1
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 2
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 3
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 4
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 5
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 6
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 7
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 8
Dec 31 16:00:13 kernel: Buffer I/O error on device sda, logical block 9
Dec 31 16:00:13 kernel: end_request: I/O error, dev sda, sector 56
Dec 31 16:00:14 Samba Server: daemon is started
