Is Wireless Roaming a Standard Feature?
Don't the C7's have some firmware issues relating to wireless client associations of certain devices? Did they correct?
Don't get a C7.
2.4 GHz performance is significantly worse than an amped wireless device it was supposed to replace.
5ghz is okay but not spectacular.
Mine is going back.
Sent from my SCH-I605 using Tapatalk
I still have the amped; I think it's the r10000. I was looking to upgrade to 802.11ac but I'll just wait until I have an AC device or two now ;)
The Archer c7 has lower signal levels and very poor throughput in the 2.4 GHz band.
Added on edit:
Another user in the C7 specific thread had a pointer to a new beta which does have better throughput on the 2.4 GHz radio.
Roughly comparable to the Amped now.
Added on edit:
Same WiFi channel in use?
