Thanks!!Here he is, #185
https://www.snbforums.com/threads/h...us-routers-380-68-updated-08-24.33638/page-10
Cheers.
Yea not much new things where happening on the open VPN section. but I am ready for anything you throw at me384.5 should keep him busy, since I'm in the process of revising various aspect of the OpenVPN configuration.
- CHANGED: Revised OpenVPN server options:
o Removed "TLS Reneg time" (rarely used, can manually
be set as a custom option)
o Removed "Server Poll" (which didn't work
properly)
o Removed "Push LAN" and "Redirect Gateway",
replaced with new Client Access setting
o Removed Firewall setting (firewall rules are now
always created, and the broken External mode
was fixed and integrated into the new Client
Access setting)
o Removed option to respond to DNS queries - enabling
the option to Push DNS will also handle it
o Added new Client Access setting to select between
three types of access: LAN only, WAN only (will
block access to the LAN, including the router
itself) and LAN + WAN.
- CHANGED: Revised OpenVPN client options:
o Removed "Poll Interval" (which didn't work properly)
always created)
o Modified behaviour of Connection Retry. Instead
of taking a value in seconds that only affected
resolution failure, it now takes a number of attempts,
and affects connection failures. Resolution failures
will now retry for an infinite period of time (the
default OpenVPN value).
I have a router freed up and ready to test when the code is ready. I rely on OpenVPN Server for remote access to several sites. I also have the blog posts with the OpenVPN Client and Server setup instructions that will need updating.So far (this is just after a first pass at them, still have things left on the ToDO list
Code:- CHANGED: Revised OpenVPN server options: o Removed "TLS Reneg time" (rarely used, can manually be set as a custom option) o Removed "Server Poll" (which didn't work properly) o Removed "Push LAN" and "Redirect Gateway", replaced with new Client Access setting o Removed Firewall setting (firewall rules are now always created, and the broken External mode was fixed and integrated into the new Client Access setting) o Removed option to respond to DNS queries - enabling the option to Push DNS will also handle it o Added new Client Access setting to select between three types of access: LAN only, WAN only (will block access to the LAN, including the router itself) and LAN + WAN. - CHANGED: Revised OpenVPN client options: o Removed "Poll Interval" (which didn't work properly) o Removed Firewall setting (firewall rules are now always created) o Modified behaviour of Connection Retry. Instead of taking a value in seconds that only affected resolution failure, it now takes a number of attempts, and affects connection failures. Resolution failures will now retry for an infinite period of time (the default OpenVPN value).
Welcome To SNBForums
