Hi there, I'm a new member to this forum. I have a weird problem with an AC-68U router running Asuswrt Merlin. The router was previously part of an AiMesh system. The main router is an AX-58U running Asuswrt Merlin 386.2_2 (router A). Until yesterday the AC-68U router has been working well in the AiMesh system, running Asuswrt Merlin 386.2_2. There were 4 AiMesh nodes in the system yesterday, all connected via 1G ethernet to the AX-58U. The main router A and 2 of the nodes are running 386.2_2, one is running 386.2_4 and the other 386.2_6.
This morning I tried to add a fifth AC-68U router running Asuswrt Merlin 386.2_6 (router B). This is where the problem starts I believe. The node addition process failed with a message in the main router A: "Unable to add your AiMesh node RT-AC68U (<mac addr>) to your AiMesh system due to the following situations. Please check and try again.". The message continues to list 5 possible reasons for the failure, which have all been ruled out. I thought that an AiMesh node is limited to 4 nodes, so I removed one of the working AC-68U that is running 386.2_2 (router C). I then tried to add router B again, but the problem remains.
After this I tried to add router C back into the AiMesh system. Surprisingly I'm getting the same error message adding this router, when nothing has been done to the router (other than removing it from the AiMesh system earlier). I tried it the second time after resetting the router (using the WPS button procedure), but it failed as well. I then upgraded the firmware to 386.2_6 to see if it solves the problem, but that failed as well.
Thinking that the problem might be in the main router A I then rebooted the AiMesh system, which I believe should have rebooted the main router and the 3 existing AiMesh nodes. Once everything is back up and running I tried adding router C back into the system (still running 386.2_6), but the process failed with the exact same message in the main router A.
I have not tried (mostly because I don't want to disturb an otherwise working system) to sync up the firmware of the main router and the 3 existing nodes to 386.2_6.
Does anyone know how to resolve this issue? Any help would be greatly appreciated!
