I've put a html file abc.html in /www/ext
I want to share the page with all the computers in the LAN.
Let's say PC A access the page
Is it possible to bypass the authentication? Not all the users in the LAN know the login data. I just want to share something.
If I continue to login into the router I am able to access the page.
Another issue is that, at the same time if PC B try to access this page, it will get the error
Is there any way to bypass the check and let user access the page at the same time?
, it will ask you login the router.
Login user IP: PC A
You cannot log in unless another user logs out first.
