flyboytyler
Now getting the following message for my attached drive, I have disconnected it and ran chkdsk and scan disk from windows, no issues reported. Anyone have any ideas?
Aug 10 13:20:34 kernel: usb 1-1.1: new high speed USB device using ehci_hcd and address 4
Aug 10 13:20:34 kernel: usb 1-1.1: configuration #1 chosen from 1 choice
Aug 10 13:20:34 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Aug 10 13:20:36 kernel: scsi 1:0:0:0: Direct-Access Seagate GoFlex Desk 0D16 PQ: 0 ANSI: 5
Aug 10 13:20:36 kernel: sd 1:0:0:0: [sdb] 732566645 4096-byte hardware sectors (3000593 MB)
Aug 10 13:20:36 kernel: sd 1:0:0:0: [sdb] Write Protect is off
Aug 10 13:20:36 kernel: sd 1:0:0:0: [sdb] Assuming drive cache: write through
Aug 10 13:20:36 kernel: sdb: sdb1
Aug 10 13:20:36 kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Aug 10 13:20:36 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Aug 10 13:20:37 hotplug[693]: USB /dev/sdb1(ntfs) failed to mount at the first try!
Aug 10 13:20:37 kernel: ufsd: use builtin utf8 instead of kernel utf8
Aug 10 13:20:44 hotplug[693]: USB ntfs fs at /dev/sdb1 mounted on /tmp/mnt/FREEAGENT_GOFLEX_DRIVE
Aug 10 13:20:44 kernel: ufsd: sdb1 without journal
Aug 10 13:20:46 hotplug[693]: USB partition unmounted from /tmp/mnt/FREEAGENT_GOFLEX_DRIVE
Under the Scan section it shows:
Non standard sector size 0x1000 bytes
