I seemed to be having a unique issue that has challenged Asus support. Hoping someone can help and/or has seen similar situation. I went out and bought two RT-AC87U routers. Which provide outstanding performance when up and running! Very impressed! My problem is I can’t seem to keep them up. I’ll explain…
I have a two-story home. On the first floor I have one unit setup as a router. On the second floor I have another unit setup as an AP. What happens at least 3-4 times a day is my network goes down and Internet is lost. Well mostly lost if not completely lost. What I mean by that is when the issue arises Internet is down from the AP for sure. Sometimes I can switch to the router (wirelessly or LAN) and I will still have Internet. Other times its down for my entire network. What’s strange is I seem to maintain access to all devices on the network no matter if connected to router or AP. Now incoming traffic to my Plex server on my network is blocked. Here is what is strange… if I power off the AP all is fine. Router returns to normal, internet is restored and remote access is granted. Power the AP back on and works great until next crash.
Let me explain what I have done and/or tried to eliminate the problem:
1. Updated both units to latest firmware on Asus support to 3.0.0.4.376.2769. And now Merlin's 376.47
2. When setting up second unit in AP mode I have tried the following:
a. Set LAN to obtain IP automatically – No luck
b. Set LAN to static IP – No luck
c. Set LAN to static IP on different subnet – No Luck
d. Set LAN to static IP and configure router to skip the IP in DHCP – No luck
e. Configured unique SSID names for not only 2.4 & 5g bands but also unique of what router is using.
f. Manually set channel for 2.4 bands. Channel 4 for router and 9 for AP.
g. I have also rebooted both units after every settings change and have done a factory restore on both units multiple times.
3. When speaking with Asus tech support I was at one point advised to replace the router with a new unit as it was defective. I have done this. No luck. I have also switch the two current units I have to see if maybe my other unit was the issue. So unit that was a AP is now a router. Same problem.
What I have noticed is when the issue comes up I can no longer ping the router through the AP. I feel like the AP locks up the router and the minute I power off the AP everything returns to normal.
Something that I had come across a few times during setup of the AP is when I set the LAN IP to static and assign an IP, there are times that the IP changes on its own and takes on a new IP from the router even though its set to static. One time even though the UI showed a LAN IP I had assigned I was accessing it through the browser through its default setting of 192.168.1.1
My gut feeling is there is some kind of firmware bug and the AP is switching IP and conflicting on the network thus taking the Internet down. At one point I lowered the lease time on the routers DHCP to 2 minutes to see if it happens when the AP obtains a new lease and that didn’t seem to affect it. It just happens randomly and can be anywhere from after 15 minutes to after 1 hour to after 5 hours. But eventually it will go down and powering off the AP returns everything back to normal. Even without rebooting the router.
If anyone has any suggestions that would be great! I have called Asus support many times and been emailing their support team back and forth for two weeks now. No luck. ☹
