On the DSL-AC68VG, correct?
ifconfig
method was originally from here - https://www.snbforums.com/threads/access-modem-configuration-page.11957/"iptables"
command shown in that thread but perhaps you need it for PPPoE?Here is the full picture after the route command to the RT-AC86U.
ifconfig ppp0:0 192.168.0.2 netmask 255.255.255.0
Having had a think about it, since your (PPPoE) WAN interface, your ISP's Gateway and DNS addresses are going via "ppp0", then perhaps we should specify that interface instead in the "ifconfig" command. To that end, if you wish, try this in an RT-AC86U telnet/SSH session -
Code:ifconfig ppp0:0 192.168.0.2 netmask 255.255.255.0
Then attempt access to the bridged modem via a browser from your desktop PC.
Yep!In case it fails, with a simple reboot of the RT-AC86U I can revert all the changes, right?
Yep!
Well I appreciate your efforts but none of the solutions worked. I have read through the other topic you linked in, all of the users there have their modems set to bridge mode. The thing is, in my case the DSL-AC68VG bridge mode did not work and I only had to disable the 802.11Q function to be able to establish a PPPoE connection through the RT-AC86U. I wonder if this is causing the troubles for me...![]()
Okay. I didn't realise you failed to bridge the DSL-AC68VG, as I thought you achieved that in post #7. So you're running with double-NAT then.
I guess it's see how you go with the RT-AC86U running a VPN on it as you intend.
I do not think that I have double NAT. The RT-AC86U connects to the internet via PPPoE connection and gets a WAN IP from the ISP
Okay, but you stated -
So I assumed the DSL-AC68VG was still NATing. Perhaps it's because you removed the VLAN ID from the DSL-AC68VG that the WAN IP is passed through (it's as if NAT is disabled on the DSL-AC68VG)?
Yep, but I'm sure you could get it to work using the "Plan a) Same subnet" method.Still it is unclear why no solution works for accessing the modem directly other than keeping separate wireless networks alive on that device.
Get your timing right so as to not drop internet access to the rest of the household when you do thatYes, this works. It is easier to temporarily switch the cable from the WAN to the LAN port on the RT-AC86U than enabling the wireless radio by hand on the DSL-AC68VG.
top
.Get your timing right so as to not drop internet access to the rest of the household when you do that
I've no idea if the DSL-AC68VG is continually attempting to connect/authenticate with your ISP, or chewing up CPU - perhaps check its log and also withtop
Up to you of course, but if budget permits perhaps buy another modem/router that's easy to bridge. A second-hand Technicolor modem/router would suit well as they're very easy to bridge.
I don't know where you're located, but do you have the Draytek Vigor167 available? It comes with bridge mode set as its default - it couldn't be any more "plug 'n play".
Welcome To SNBForums
