Both routers are AC66U using the latest shibby build. I cannot seem to get these 2 connected when I use encryption (tried many wireless channels on both). With any encryption (WPA, WPA2, WEP, etc.), the WEB will NOT bridge correctly (i.e. none of the wired devices on the bridge receive an IP). However, when I turn off encryption, they connect fine and everything works. I've obviously checked the passkey and other obvious stuff.
I'e used the stock firmware and it works fine under encryption, but tomato is the only firmware which has given me near perfect QOS.
Is this a known issue? It seems ridiculous that a simple wireless bridge can't work with encryption under tomato.
