BCM4912 has two SXGMII ports, BCM4916 has three SXGMII ports.You mean the 4916 right?
That's why the GT-AXE16000 is able to provide two 10 Gbps ports.
That's a NAT/CPU limitation, not Ethernet limitation.I was having issues with the GT-AXE16000's 10Base-T ports which showed just barely 2.6 Gbps wired speeds as tested on Ookla with the full AiProtection suite turned on.
I don't know. You could try installing ethtool from Entware and try it out, unless you can figure out the syntax for BCM's own switch control tool (I forgot its name).Can those 10-Gb ports have hardware flow control configured?
No, but you might need to reconfigure/reset any VPN configuration, as our implementations are different.Do I have to do a factory reset after loading Merlin firmware on a gt-axe16000?
Is a reset indicated for AX88U with 386.8 too?No, but you might need to reconfigure/reset any VPN configuration, as our implementations are different.
Doing a factory default reset is probably a good idea tho. It seems that earlier builds of the stock firmware were leaving some large variables into kernel nvram, which is limited to 128 KB. Doing a factory default reset with the latest stock firmware or with 386.8 will probably move these to JFFS.
No.Is a reset indicated for AX88U with 386.8 too?
Thanks for the insight. If the CPU is the bottleneck, I'm guessing no firmware revision's going to fix the lousy wired speeds for 10G. Or would a hardware revision by Asus do the trick? From what I've read on the RT-AX89X threads on the forum, there were at least 4 hardware revisions before the SFP+ and 10G-BaseT speed issues were ironed out. I'm holding onto my later version RT-AX89X for that very reason before deciding whether to pull the trigger on another AXE16000, after returning the first two.That's a NAT/CPU limitation, not Ethernet limitation.
Running iperf on a GT-AX11000_Pro and GT-AXE16000 Pro connected together over their 10 Gbps interfaces, I can get 3.2 Gbps - and the bottleneck is the CPU not being able to run iperf fast enough to generate more traffic.
Thank youNo, but you might need to reconfigure/reset any VPN configuration, as our implementations are different.
Sorry wasn't fully awake when I posted this. I'm guessing that a firmware update by Asus developers/RMerlin could boost the CPU performance on the router similar to overclocking your Intel/AMD CPUs.Thanks for the insight. If the CPU is the bottleneck, I'm guessing no firmware revision's going to fix the lousy wired speeds for 10G. Or would a hardware revision by Asus do the trick? From what I've read on the RT-AX89X threads on the forum, there were at least 4 hardware revisions before the SFP+ and 10G-BaseT speed issues were ironed out. I'm holding onto my later version RT-AX89X for that very reason before deciding whether to pull the trigger on another AXE16000, after returning the first two.
Yeah, but it's impressively fast LPDDR5 on the M2... and with Thunderbolt 4 and a 10Gbit adapter, would be a nice fit with this device
(my dell XPS13 also has soldered DDR, this is getting to be a thing in the thin and light laptop space)
For a home gateway (router/ap) - 2GB is plenty of space - and with the crazy supply chain these days, might be they got a really good deal on specific parts if they're not in high demand - the DRAM market right now is all over the place
I have only seen reports that the M2 Air is slower than the M1 Air because it now uses a single chip in the 256 GB SSD of the base model.As a 'new' for 2022 device, it is markedly below the original 8GB M1 Air performance.
If you are referring to NAT throughput, I don't expect this to be changed by a hardware revision. It's simply a hardware limitation. At those speeds, you'd need either a business-class router, or at the very least IPv6 to get rid of the NAT overhead.Thanks for the insight. If the CPU is the bottleneck, I'm guessing no firmware revision's going to fix the lousy wired speeds for 10G. Or would a hardware revision by Asus do the trick? From what I've read on the RT-AX89X threads on the forum, there were at least 4 hardware revisions before the SFP+ and 10G-BaseT speed issues were ironed out. I'm holding onto my later version RT-AX89X for that very reason before deciding whether to pull the trigger on another AXE16000, after returning the first two.
Keep in mind that my test was done by running iperf on the router itself (without NAT - I was doing LAN to LAN test, with the "client" being a second router connected in AP mode)). CPU usage was showing all three cores (I ran three threads) were 100% occupied by iperf itself, and the scaling was about right when compared to running iperf in a single thread.Might explain why nobody is seeing 10G end to end on iperf...
BCM4916 is designed for Wifi7. Maybe it could still be coupled with a BCM6715 to provide a faster Wifi 6 product (since that's connects over PCI-Express), but I doubt Broadcom is already mass producing the BCM4916 at this point. I don't know either if their SDK would support that kind of hybrid design (Wifi 6 and Wifi 7 generation products).To get to 10G on runner, one has to do the upgrade to BCM4916, hence my question on the model number
Two unrelated issues. Disk I/O is slower on the M2 using the 256 GB version due to the use of a single NAND chip rather than two chips in dual channel. This isn't related to RAM however.I have only seen reports that the M2 Air is slower than the M1 Air because it now uses a single chip in the 256 GB SSD of the base model.
Where can I read more about this CPU/memory issue?
Indeed.Two unrelated issues. Disk I/O is slower on the M2 using the 256 GB version due to the use of a single NAND chip rather than two chips in dual channel. This isn't related to RAM however.
The core issue is probably the fact that RAM isn't upgradable, and since the RAM is shared by the CPU and the GPU, 8 GB can quickly become a problem.PS: I’m “sometimes“ a bad reader; what am I missing here / this time?
The Okla speed test unless proven with other hardware to measure that type of speed is probably not going to cut it. You need a direct link between two capable machinesOokla
If the chipset dose fast switching, then the CPU only needs to tell the chipset where the buffer is in memory and the chipset moves the data out the portThanks for the insight. If the CPU is the bottleneck, I'm guessing no firmware revision's going to fix the lousy wired speeds for 10G. Or would a hardware revision by Asus do the trick? From what I've read on the RT-AX89X threads on the forum, there were at least 4 hardware revisions before the SFP+ and 10G-BaseT speed issues were ironed out. I'm holding onto my later version RT-AX89X for that very reason before deciding whether to pull the trigger on another AXE16000, after returning the first two.
I've just heard back from Asus Tech Support regarding my crap download/upload wired speeds on 10Gbps broadband and this was what they said verbatim:The Okla speed test unless proven with other hardware to measure that type of speed is probably not going to cut it. You need a direct link between two capable machines
We use essential cookies to make this site work, and optional cookies to enhance your experience.
