jffs connection/transcript error
thirk
Hello !
recently i have got a problem connecting and copying scripts to my routers jffs scripts folder.
i´am running 380.62_1 on asus RT-66NU using Interarchy with SCP protocoll to connect.
this has worked fine for me until recently,
now it´s telling me "SCP error, check transcript"
I allready did a clean install and partitioning , do you have some ideas what might be the problem here.
how do you connect and upload firewall scripts etc. ?
Thanks for your Your help and Suggestions !!
Yes. If you formatted the JFFS partition on next boot, you would need to reboot it a couple of more times for it to be usable. ;)
