John's Tool - 1st attempt at using
TheLyppardMan
I've formatted a USB flash drive and attached it to my Asus RT-AC68U as per the instructions, but after logging in via Telnet and enetering the 1s /mnt command, I don't see what I am supposed to see. Can someone advise please?
The command is called 'ls' :rolleyes: - not '1s'! :eek: You get the difference? ;)
And: Did you reboot to mount the device? Or you have to mount it manually!
This is the problem with the numeral one, lower case L and upper case I characters. Depending on the font/program, these characters can easily be mixed up. Similar problems can happen with the letter O and the number zero. I'll give it another try tomorrow.
It's worked fine this time. Easy when you know how!
