just noticed JFS is enabled , any reason It should be enabled
jerry6
if I'm not running anything special ,first timr I've seen the warning on the Admin FW upgrade page .
Don't remember if I have ever enabled or turned it off before , should I turn it off ?
Just leave it on.
JFFS is now enabled by default to be in-sync with Asus's own default setting. There is no reason to want it to be disabled quite honestly.
thanks will leave as is .
.41 Exclamation Mark after Firmware Download
Guess my post was for the same question! I won't worry about it on mine either.
