Just upgraded to 3.0.0.4_374.43..question
d_v_us
Hello fellow Asus peps....just upgraded my RT-N66U to 3.0.0.4_374 and no real issues to speak of right now. Only question I do have is, after upgrading I was lookin to clear NVRAM again just because:) (I made sure telnet was enabled). I went to the URL that I always do and it doesn't seem to work....I just keep getting the spinning wheel....I also watched the LEDs but nothing seemed to be happening. Here is the URL that I was using prior to upgrading: (http://192.168.X.X/Main_AdmStatus_Content.asp).
Of course there are other ways to clear NVRAM....in my case I just went to the Professional tab and just hit "restore to factory settings". I guess I was so used to using that page to clear NVRAM...does anyone else do it that way or having the same problem.
I've just tried running (on AC56u) that command on latest stock .5656 Fw and yes...wheel is spinning but nothing is happening.
AFAIR telnet has been disabled/banned along with the latest security updates for newer FW..this is true for stock and consequently for Merlin.
,,,you must use SSH instead.
