Kamoj Kamoj add-on V5 for Netgear R7800 X4S and R9000 X10
Thanks a bunch for this awesome add on. I have everything setup, but when I try to enable DNSCrypt on Voxel R7800 (1.0.2.82SF), the radio button highlights, but then de-selects and selects None again. Is there some piece I'm missing? I see in the above post you mention 1.0.2.82.1SF has issues, does 1.0.2.82SF also? I didn't see any other precursor to enabling it.
Thanks!
Yes, you are right. You must go back to 1.0.2.81.1SF to get compatibility.
Sorry for the problem!
Thanks!
Just wanted to report a few bugs I had with the Kamoj addon on my R7800. Not sure if these have been reported before
1) QoS Automatically Enables itself after every reboot
2) Was having this weird issue where Access Control was unable to unblock a device. I would goto Edit, change Block to Allow and maybe change the Name. The name would update, but the device would remain blocked
This was on the firmware - R7800-V1.0.2.80.7SF - not sure what Kamoj version it was though - though probably a version released in early Dec. I had updated both together and the next Voxel FW came on the 17th of Dec, which was not out yet at the time
I uninstalled the addon and everything started working normally. Has anyone encountered such issues?
Ps: Looks like ge.tt is shutting down soon. Might need to host the beta elsewhere
hi kamoj
Recently, i notice a problem that i can't change any setting in kamoj addon page with firefox, but using chrome base browser can.
this problem only happens on addon page, idk why.
hi kamoj
I'm going to suggest it might have something to do with Firefox's javascript implementation in their browser engine. You'll probably find that if you test by using Edge browser, it also works (same engine as Chrome). I've had this (not often) happen on some websites that make heavy use of javascript.
Also, I personally haven't experienced any issues using Firefox with kamoj's add-on, have you tried clearing your browser's cache to see whether that helps?
I tried the "usual ways"
Clear Firefox cache, didn't work.
Switch off ad-blocker addon, didn't work.
Switch off build-in tracking protection stuff, didn't work.
Browse with firefox "incognito mode", didn't work.
Finally, reset the entire browser, also didn't work.
Looks like the kamoj add-on setting page hate firefox. ;_;
thanks for your suggestion anyways.
I have followed the installation steps for this addon on my R9000 mainly to test Wireguard but I cannot see any Wireguard client under "Kamoj Menu". Am I missing something?
TNX Kamoj & Voxel,
Answering myself: no wireguard GUI client on Kamoj addon in 5.0 version. For that purpose please proceed:
I noticed that the DNSCrypt does not always start correctly with the add-on after the restart.
It may be because of DNSCrypt changed it's configuration?
From Opening Post of this thread:
This version of the kamoj add-on is not compatible with the DNSCrypt version in later Voxel R7800 (1.0.2.82.1SF) and R9000 (1.0.4.47HF).
You must stay with Voxel 1.0.2.81.1SF / 1.0.4.46HF, or not use the kamoj GUI for DNSCrypt to keep DNSCrypt compatibility, see:
https://www.snbforums.com/threads/k...ear-r7800-x4s-and-r9000-x10.60590/post-661166
oh it's my mistake didn’t read the whole post to the end
Thank)
I am on Voxel V1.0.2.82 and in http://www.routerlogin.net/debug.htm I don't see any options to enable telnet
EDIT: Think I auto-updated and got off of Voxel :D Installed the recommended version, kamoj, and got the ad blocking running with dns encryption. Thanks!
I had previously been using Voxel/Kamoj for a long time and have been testing out DD-WRT for 6 months and I'm now looking to return to Voxel/Kamoj.
I was previously running the Beta versions of Kamoj but I can see that you've changed the process and access to the Beta.
Can you tell me what version the instructions on the first post install?
The first post was updated on 21/05/2021 so just checking if you updated the version to a newer release, as this previously used to be a very early beta version.
Hey Kamoj,
I had a question for you, but first my specs:
R7800, FW:V1.0.2.81.1SF (Voxel). Kamoj Add-on: 5.00.
I have my router set up behind a modem, connected to the WAN port on the modem. The router handles all the routing for part of my network, and passes the internet connection through to the modem.
However, every so often (rather regularly, perhaps every 16 hours or so), the R7800 becomes invisible to my network and everything is still passed through, but I can no longer connect to the router, or anything connected to the router. All traffic routing APPEARS to be then handled by the modem instead of the router. When this occurs, the adblocking function stops working, I can't connect to the router through the web interface, and I can't access the external hard drive on the network anymore.
I don't know enough about networking to know why this is happening. I'm assuming it's a bug in the firmware, but I don't know if it's in your addon firmware, or in Voxel's base firmware. Unfortunately, I can't check if it's Voxel's firmware, because you don't support any newer versions of his firmware, and I consider your addon to be essential.
Have you any idea what might be causing this issue? When it occurs, I reboot the router (manually) and it functions normally again. I tried setting a script on the router that reboots it every day, but I don't think the script is running properly. The router doesn't seem to be rebooting itself.
Thanks.
I can't explain your issue at all, and doubt the add-on has anything to do with it.
What are the temperatures in the router?
The new add-on has quite a number of supervision, logging and restarting functions that might help.
You can join the beta testing, or wait some more time for the new add-on to be public.
Hey Kamoj,
Thanks.
Hi Kamoj,
Danlat hooked me up with the beta version, so I'm all updated. You've added a lot of new features. I'm still testing, but the new firmware seems to be faster than the old firmware. Will have to post back later with long-term results. Temps seem slightly high - 147° (~64 C?) while tooling around with settings in the Kamoj menu. Router is on a wood shelf in an airconditioned room.
I will add one thing though: I do wish there was an easy way to add different adblock lists and have them update automatically. I use a couple of the presets and then manually add the EasyList to the Blacklist filter. Seems to work good, but requires manual updates.
Love your work. Your modded firmware is a huge step up from the Linux derivative I was using before. So many options, and easy to use.
Hi Kamoj,
Is there a way to let the VPN Bypass do the opposite.
Only let certain devices use the VPN?
